18 Wheels for 2000 Excursion
Old Feb 24, 2021 | 02:18 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
OK, so i found some Fuel wheels, 18x9 with a -12mm offset, will these fit properly? Also, i found the same wheels with -18mm offset, would these fit better, or which should i get???
I am not lifted at all, i am stock height, with coil spring front end.
Old Feb 25, 2021 | 09:31 AM
blk_fxstc's Avatar
blk_fxstc
You want something with around zero offset for that width wheel. The -12mm would be the best out of those two choices, it would stick out 1/2" farther than something with zero offset.
Old Feb 25, 2021 | 11:54 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
bumping, will these fit and be the proper offset, etc to not end up with any problems with rubbing with either 285/75/R18 or 285/65/R18 Tires
Wheel specs:
Manufacturer Fuel
Manufacturer Part Number d53118901745
Item Number FUE D53118901745
Wheel Diameter 18 in.
Wheel Width 9 in.
Wheel Bolt Pattern 8 x 170
Wheel Backspacing 4.5 in.
Wheel Offset -12mm
Wheel Finish Matte Black
Wheel Material Aluminum
Wheel Load Capacity 3,700 lbs
Old Feb 26, 2021 | 09:41 AM
1997expo4x4's Avatar
1997expo4x4
I have a set of 18 inch lariat wheels that I am thinking about selling. I am planning on swapping to 2005+ axles. I am in the chandler-Gilbert area.
Old Feb 26, 2021 | 09:44 AM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
Pics? But i kinda want the Fuel wheels i mentioned if they will fit properly, hoping someone who knows the proper info will reply before i order them.
Old Feb 26, 2021 | 10:03 AM
WE3ZS's Avatar
WE3ZS
Site sponsor Custom Wheel Offsets has what seems to be a pretty good online figment tool, have you tried plugging in your specs there yet?
https://www.customwheeloffset.com/? I haven't played around with it as I'm perfectly happy with my OEM 18"s, but have read where it's helped several other members around here.
Old Feb 26, 2021 | 12:24 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
Can you post some pics, and a price? if its right i might just come over and snag them, i got ahold of someone who knows and those fuel wheels will not fit right
Old Feb 26, 2021 | 12:25 PM
1997expo4x4
I’ll be back in town next week and will take some pictures.
Old Feb 26, 2021 | 01:21 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
If they are in decent condition i will probably take them.
Old Mar 1, 2021 | 11:16 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
Bump very interested, and i would pick them up
Old Mar 2, 2021 | 09:29 PM
1997expo4x4
I will be back in town tomorrow. Got delayed by the transfer case bolts backing out on my ex. First time I’ve seen that happen. Tow truck driver made the situation far worse and now the transfer case motor and multiple wires need repair.
Old Mar 2, 2021 | 09:33 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
Could be worse, saw a flat bed wrecker with a big F-350 sized work truck on the back take a right turn with a tiny little bit of speed, jump the curb with his back wheels and almost go over completely, on the backswing/recoil the truck he was carrying smacked the traffic light pole, he just kept driving pretending nothing happenned.
Old Mar 5, 2021 | 09:56 PM
  #28
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
i sent you my number in a PM
Old Mar 10, 2021 | 06:49 PM
  #29
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
Hey buddy, looking forward to getting hold of ya for those wheels.
RenoHuskerDu
Oct 9, 2017 01:53 PM
housedad
Nov 17, 2009 10:01 AM
dfmatt
Feb 26, 2007 11:41 PM
newford
Feb 22, 2001 01:46 PM
