good afternoon, i have a 2014 f150 xl the airbag light has been on for as long as I've owned it. I had it scanned today and they said it was "B0095: 93 Right Frontal Restraints Sensor: No Operation"
but to specifically know what is causing it, can anybody specifically tell me what i need to do to fix this or point me in the right direction as to which sensor or module is faulty, wire, etc
thanks in advance for the help
Check the right front sensor for being plugged in properly, it's located next to the radiator about 2/3 the way down. Disconnect the battery ground cable and turn the ignition switch to the on position, leave the truck sit for 30 secs then disconnect and reconnect the sensor several times. Reconnect the battery and fire the truck up. If the airbag light comes on then goes out and stays out, you fixed the problem, if the light comes back on some computer diagnostics will be required.
