any ideas ??
Old Feb 17, 2021 | 02:44 PM
AZoldfart's Avatar
AZoldfart
any ideas ??
We have a 1988 F350 Super Duty Lariat. We are doing some equipment/parts replacement and need some ideas on replacing the Air Clean Cold air intake... the old one is broken and crack and we have not been able to resource a replacement / substitution on Ebay or anywhere else... Has anyone else had to replace this part? Where did you find one? Did you find an alternate solution (what, and where can I buy/find it /make it)? Is there a K&N part that will fit and what is the part number.
This is what we know / have found:
The OEM part number is E8TE-9C675-BA
One similar part found on ebay... but it is for a 95-96 F350 and does not have the "accordion" center (which is the area that is broken and cracked)
So far the only solution we can come up with is to "construct" a metal adaptor to go from the square part to round accordion hose (to be secured with large hose clamps)
ANY ideas or help will be much appreciated
Old Feb 17, 2021 | 03:38 PM
Mikulh's Avatar
Mikulh
I believe the smooth ones are interchangeable with the accordion ones... at least I hope so, because I just bought a new smooth one to replace my broken accordion one.
I'll let you know after I try to install it, but that may be a while since we're covered in ice right now.
Old Feb 17, 2021 | 03:47 PM
rla2005's Avatar
rla2005
This thread has some information on your air intake tube questions: https://www.ford-trucks.com/forums/1...l#post15628073
The later version used on the OBS trucks with the 4.9L and 7.5L is very close to the same.
I found the later version, F3TE-9A675-BB, on E-Bay years ago.
Old Feb 17, 2021 | 05:21 PM
wwhite's Avatar
wwhite
I picked one up in the past year, same for 4.9L and 7.5L as mentioned above.
I think I found it on a 4x4 bronco forum, signed up just to communicate with the guy.
$10 USD last year.
Keep searching different forums, and post wanted ads, someone will have it.
Old Feb 17, 2021 | 10:14 PM
SoaDMTGguy's Avatar
SoaDMTGguy
Is there a junkyard near you that you could go to? I’ll take a look next time I’m at Pick-N-Pull, see if I see a matching intake.
Old Feb 22, 2021 | 08:31 AM
Mikulh's Avatar
Mikulh
FYI...The smooth one installed in place of my accordion one with no issues.
Old Feb 27, 2021 | 09:18 AM
AZoldfart's Avatar
AZoldfart
Found one on Ebay that fit a '92-'96 ... Had to take the bracket off the old one and use short self tapping screws to replace the rivets.. but it went right in and works great.
tattooed_pariah
Aug 13, 2020 10:22 PM
Parker Hawkins
Apr 17, 2020 01:09 AM
Nem28
2004 - 2008 F150
May 29, 2016 09:07 AM
SpeedRicer
May 17, 2016 01:53 PM
Phased3
Large Truck
Oct 25, 2015 07:56 PM
