Sponsored by: Real Truck
Wide track axle
Old Feb 15, 2021 | 03:06 PM
Adesros's Avatar
Adesros
Wide track axle
Have a 2009 f350 Harley, Needing to order a new front outter tie rod. How do I tell if I have the wide track axle set up or not
Old Feb 15, 2021 | 08:38 PM
ifrythings's Avatar
ifrythings
Wide track is any truck with a box, narrow track is cab and chassis trucks.
Old Feb 16, 2021 | 02:14 AM
Eaglescout94's Avatar
Eaglescout94
Wide track should be the super 60 which were dually only. If you’ve got it you have large factory fender flares.
Old Feb 16, 2021 | 08:04 AM
Adesros's Avatar
Adesros
i have the SRW truck but it has the factory fender flares that come with the Harley edition
Old Feb 16, 2021 | 08:25 AM
Desert Don's Avatar
Desert Don
The “wide track” is typically found on the F450 and the F350 “wide track” which is a specially equipped dually. .
Old Feb 16, 2021 | 08:35 AM
ford390gashog's Avatar
ford390gashog
The only wide track pickup was the F450.
Old Feb 16, 2021 | 08:56 AM
BuddyB's Avatar
BuddyB
Wide track was only available with "max tow package" F-350 (of course also the F-450). Things that make the "Max tow" are 1 ) dually 2) 4:30 gears . These are the two basic items you need. You will also get the extra wide front fender flares to help with the turning radius. Also, I thing the "wide track" F-350 went away in either MY 2015 or 2016
Old Feb 16, 2021 | 10:09 AM
Desert Don's Avatar
Desert Don
Yup........ “TOW BOSS” was the term I was trying to think of. And you are correct, MY 2016 was the last year.
I think this one belongs (or belonged) to a member here on FTE.
Old Feb 16, 2021 | 09:17 PM
ford390gashog
The wide track F350 was only available for two years 2015 & 2016. This was a rebaged F-450 as Ford severely neutered the F-450 from 2011-2014 and it rode on the F-350 platform with 8 lug wheels. The revised F-450 arrived in 2015 and lasted just two years. The 2017+ trucks received the smaller rear axle that's shared with the F-350 DRW.
Old Feb 17, 2021 | 04:26 PM
fordpower88's Avatar
fordpower88
The wide track F-350 was available for more then two years. It was available starting in '08 for sure as I own one.
Old Feb 21, 2021 | 07:41 PM
diesel_dan's Avatar
diesel_dan
I'm helping a friend try to find one of these, and I have to call BS - the wide-track was available on the DRW's in 2008 and 9, and then 2011 to 2016 MYs... Please correct me if I'm wrong... I'm hoping to find a '15 or '16 4x4 F350 6,7 WT for him...
Old Sep 24, 2021 | 08:32 PM
Diesel_Brad's Avatar
Diesel_Brad
I know, Late to the party.
But the widetrack was available from......
08-10 on F350 duallys. They had the large front fender flare if they had the wide track axle, but the widetrack was an option, not standard
The 05 current F450/550, large front fender flare
15/16 F350 duallys, again had large front fender flare if they had the wide track axle, but the widetrack was an option, not standard
The 11-14 F450 Pickup also had the wide track axle but came with 17" wheels like the f350
Tie rods at the treaded part are 1/9/16"(NON wide track is 1-3/8)
Wide track knuckle(the part that moves) is 12" tall, NON wide track is 10.75" tall
F-1
Ford Truck Parts for Sale
Feb 8, 2018 01:13 PM
Mpollard1990
1997 - 2003 F150
Dec 4, 2017 06:19 PM
1990FRANKENTRUCK
13
Oct 26, 2016 06:53 PM
dtgl90vt
Aug 14, 2013 04:03 AM
irondragon79
Apr 12, 2013 01:00 PM
