7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
7.3 Tranny temps
Old Feb 15, 2021 | 01:09 PM
Randy Spiker's Avatar
Randy Spiker
7.3 Tranny temps
We picked up our new F-350 with the 7.3 on Friday February 12 and took it out for a 225 mile spin yesterday. The truck is unloaded and outside temps were ranging from the upper 30s to the mid 40s. Throughout the drive I monitored the tranny temp display and it ranged between 206º and 218º. Is this normal? I came from a 2014 Tundra with the 6 speed tranny and temps usually ranged from 198º and 206º under similar conditions. What are y'all seeing as far as tranny temps go under normal, not polar vortex conditions?
Old Feb 15, 2021 | 03:17 PM
Veltech's Avatar
Veltech
I have a 450, I think cooler maybe bigger, but I've noticed anywhere from 195 to 215. Seems it like to settle around 210 usually. Havent really towed yet though
Old Feb 16, 2021 | 07:02 AM
4RXLA's Avatar
4RXLA
That’s normal.
Old Feb 16, 2021 | 10:35 AM
Randy Spiker
Another interesting observation...yesterday when I drove up to Lake Tahoe, as I started climbing, the tranny temp bar gauge was already resting at normal or about halfway. The tranny temp was 160. By the time I reached the summit, the tranny temp had climbed to 218 yet the bar gauge hadn't moved. That's a 58 degree change in temperature yet the bar gauge showed no movement. That just doesn't seem right.
Old Feb 16, 2021 | 05:51 PM
2five7's Avatar
2five7
The coolant temp gauge is the same way on my ecoboost truck. Halfway was anything from 180-230, soon as you hit 231 it starts climbing, 250 is the red. I think Ford just does it that way on purpose.
Old Feb 16, 2021 | 06:32 PM
KU4OJ's Avatar
KU4OJ
The oil gauge is much the same. Not really a gauge but an "indicator." and if it's in the middle it's happy. Ford has done it this way because customers noted a real oil pressure gauge would indicate a lower pressure at lower RPM and some customers just couldn't accept that this is normal. And here we are overthinking transmission temperature.
I do like the idea the transmission temp is available as digital. And yeah, it would be nice for Ford to publish what normal ranges really are. But if it's in the middle, it's happy.
Old Feb 16, 2021 | 06:38 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
RIght or not, that's how it works. Ford has determined what the normal range is, and if the trans is in the normal range the gauge is going to be right in the middle of the normal range.
Old Feb 16, 2021 | 09:44 PM
Randy Spiker
I have seen a few photos on this forum from folks who have the temps in small font right above the bar gauges similar to the "xxx Miles to E" present above the fuel gauge. I dug a little deeper and yes, there is a sub forum here called "Forscan" that talks about being able to program that into the system. It looks somewhat complicated and I'm not sure I wanna go there but I may ask the local Ford service department if they could reprogram the system to add that to the display. I like seeing real time numbers and so long as I have an understanding what is considered "beyond threshold", I'm okay.
Old Feb 24, 2021 | 10:00 PM
4RXLA's Avatar
4RXLA
My experience with Ford trucks going back to 1975 is that the gauges don’t climb above halfway unless there is a real problem. Regardless of ambient temperature or the steepness of a grade my gauges on all Ford trucks don’t move.
Old Feb 25, 2021 | 11:09 AM
super 6.8's Avatar
super 6.8
Tranny temps should be fairly constant around 98.6 degrees but I can't say I have any firsthand knowledge.
Old Feb 25, 2021 | 12:34 PM
CJWisinski's Avatar
CJWisinski
I have a 2020 F450 with the 7.3 and my highest temp hit was 221 for a few minutes when I was plowing this past week and really putting it to work transmission wise. Normally though 215-218 was the operating range. Empty highway is about 208-210. All of these temps are from the gauge cluster display. Ford has always since the 70s had oil pressure gauges and temp gauges that read "Normal" within a certain broad range and if it gets 1 degree over that range the gauge will start climbing. The transmission temp "gauges" on these trucks read middle of the normal range somewhere lower 120s I think. Like I said, "Broad" range.
Old Feb 25, 2021 | 01:03 PM
Randy Spiker
Thanks for that. I too have witnessed the "broad range" that is considered acceptable. When the tranny temp hits 150ºf, the gauge is showing it is in the normal range and it stays there all the way up to 220º and beyond though I have only seen 220º so far as the highest temp. One poster up above stated that they thought the gauge would start climbing once the temps get past 230º. Does anyone know whether this is indeed the point at which the gauge starts to rise?
My main concern is, if the temps get up to 220º with no load, I'm curious as to how much higher they run when a 7k lb trailer is hitched up and climbing a long 7% grade such as is found along the 395 corridor in the eastern Sierra. I have 750 miles on the truck and hope to hit the 1k break-in threshold today. Then I'll be able to see first hand what this thing does under load.
Old Feb 25, 2021 | 01:11 PM
CJWisinski's Avatar
CJWisinski
So I daily 10k pounds and am in fairly flat ground but some rolling hills, normally around 210. Tranny temps hold fairly steady unless the torque converter unlocks which was a major source of transmission failure up until some years ago when the engineers decided they could lock the TC before overdrive... Now in our 10 speeds it locks very very early at which point the transmission acts more or less like a manual transmission where the gears are doing the work and not the friction of the fluid in the TC. albeit of course the fluid is still holding clutch packs closed and such. So on a long steady grade with minimal downshifting I see no reason to be worried about temps. There was a guy on here who posted that he worked for a company that runs trucks 2 years and then buy all new because they pull 20k daily and do 100k miles a year. He said they bought a fleet of the 7.3 either 450 or 550s and no transmission issues to speak of but a couple of the trucks ate a transfer case each and then the motor wasnt sounding the best at 100k and had some power loss.
Old Feb 25, 2021 | 01:44 PM
CJWisinski's Avatar
CJWisinski
https://www.ford-trucks.com/forums/1...00-pounds.html
Old Feb 28, 2021 | 11:07 AM
cameronskidoo's Avatar
cameronskidoo
In cold temperatures like -30 Celsius tranny temp has a hard time reaching 30 - 40 Celsius.
Dealer said that’s fine.
I think that’s way too cold
