Transmission issue???
Old Feb 12, 2021 | 06:14 PM
lariatbob's Avatar
lariatbob
Greetings.
I have a 17 350 dually. 4:10s.
Use it as a truck, hauling stuff. A few time a year it pulls a 42 ft ~16k fifth wheel.
No matter the load when cruising down the highway in 5th or 6th I could roll on the throtte about halfway, it would spool up and the wonderful turbo torque would speed me down the road.
Lately I have noticed that often it will downshift taking the rpms to a higher than normal range and I would lose the low end pull.
Does this have anything to do with the transmission solenoids starting to stick?
Otherwise it shifts normally, no issues when pulling the trailer.
50k miles, well taken care of
Fluid and filter changed at 20k, motorcraft ft187 Motrorcraft LV fluid.
Thanks for any thoughts.
Old Feb 12, 2021 | 07:50 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If the solenoids were sticking it wouldn't shift when it was supposed to shift.
Old Feb 12, 2021 | 08:46 PM
Just Chilling's Avatar
Just Chilling
How many miles on this truck?
when was it last serviced? filters oils etc.
Do you run any fuel additives and or injector cleaners?
Also what are your driving habits these trucks do not like to idle a lot and need warmed up and run good and hard once and a while.
Old Feb 12, 2021 | 09:56 PM
sauerkraut1's Avatar
sauerkraut1
Try changing The Fuel and Air Filters ..
That should help ..
Old Feb 12, 2021 | 11:31 PM
Navajo V8's Avatar
Navajo V8
If this helps, I had my 2017 F350 DRW repaired and covered under the powertrain warranty (42,300miles). Including transfer case parts (seal, nut-hex, retainer, bolt x 2).
Transmission slipped from 3rd into 4th. I crawled underneath and I noticed transfer case seal leaked transmission, covering bottom of cab rack. I replaced 2 quarts of fluid and made an appointment ASAP. I typed out the issues and handed the document to the service manager. Luckily, I had a gentleman who called me for updates for a week.
He explained the mechanic performed adaptive learning, cleared TCM adaptive learning transmission fluid temp at 195 deg.
This procedure helps the transmission relearn procedure after transmission tuning to help the transmission perform correctly.
Service manager stated because the truck lost of 2 quarts of fluid, the transmission relearns shifting and driving habits. All trucks will experience hesitation during shifts, hard shifts, or defuel patterns, all of which are normal. So, check your transmission level and in the transfer case. Make note what problems you're having at speed and temperature. Make an appointment ASAP. We have several Ford dealership in the area. Visited several Service Managers (dealerships) and knew which one I trusted my truck with. Pending your miles and warranty, I was covered under Powertrain warranty. Hope this helps. Good luck. Truck shifts a lot better and no more slips.
Old Feb 13, 2021 | 03:46 AM
lariatbob's Avatar
lariatbob
Great to know. Thank you. I will get an appointment asap. Thanks!!!!
Old Feb 13, 2021 | 12:08 PM
4wd6.7L's Avatar
4wd6.7L
Do you use FORScan? The adaptive learning tables can be reset with FORScan. Although, if you have the time and are under warranty, it might be good to have the dealer put eyes on it. At least have it on record.
Old Feb 15, 2021 | 02:21 PM
lariatbob's Avatar
lariatbob
Thanks. I have used forscan for other items, will have to look into is for this. Not sure, do you know the warranty coverage on transmission issues?
Floridiot_Moody
15
Oct 7, 2019 11:00 AM
rocknrone
18
Jun 23, 2007 05:32 PM
CHRISRA
May 26, 2007 02:02 PM
buymore
1997 - 2003 F150
Mar 14, 2007 05:14 PM
