7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
Boring The 7.3L Block
Old Feb 12, 2021 | 02:50 PM
Louisville Joe's Avatar
Louisville Joe
I have been following some of the 7.3L builds, and it appears they can indeed make significant power. Have been wondering how far out you can take a 7.3L so far no one is talking about increasing displacement. Noticed that Brian Wolfe kind of ducked the question on REVan Evan's videos. Anyone know the story? I figure the aftermarket has to be working on pistons by now.
Old Feb 12, 2021 | 03:03 PM
ford390gashog's Avatar
ford390gashog
I would like to know the actual wall thickness from a sonic graph. Those bores are thin and not set evenly.
Old Feb 12, 2021 | 04:30 PM
Louisville Joe
Good point. Doesn't look much like core shift, looks like it was designed that way. Big as that block is I'll bet it doesn't weigh very much.
Old Feb 13, 2021 | 09:08 AM
67_4_ME's Avatar
67_4_ME
I thought I heard in one of the videos Brian said something like the block should be able to go 1 bore, maybe 30 thousand.
Old Feb 13, 2021 | 12:49 PM
Louisville Joe
I didn't catch that, but I have not watched all the videos all the way through. I do remember Brian saying something about a small stroke increase, maybe getting to 470 cubic inches. The cut block looks like you might get .030' out of it.
Old Feb 17, 2021 | 08:39 AM
GNR22's Avatar
GNR22
The variance in cylinder wall thickness reminds me of the 351 Cleveland blocks. Not a good reminder.
I remember seeing in a video, and I could swear it was one with Brian Wolfe, where they said they'd be able to bore one .030 over comfortably but they'd be scared to do any more than that even on a "mild" engine. Not sure how they define a "mild" engine since the thing is already over 400 horsepower stock. I guess if nothing else, in 20 years when these things are littering the junkyards, at least you can count on being able to clean the block up once to put in your hot rod.
Old Feb 17, 2021 | 03:52 PM
Louisville Joe
Originally Posted by GNR22
The variance in cylinder wall thickness reminds me of the 351 Cleveland blocks. Not a good reminder......
And 351M's, and 400's..... Have to admit I am a little envious of the GM 6.6L iron block. Cylinder wall thickness is the same as an LSX block, you can go .060" blown and .120" naturally aspirated. Down side is the block weighs 245 lbs. bare, I'll bet that's heavier than the Ford 7.3L
Old Feb 20, 2021 | 09:17 AM
sauerkraut1's Avatar
sauerkraut1
Bore is larger then stroke .. I would think a stroke increase would be easier .. More money though ..
Without a block deck it might be a real treat to bore .. Need to machine a fixture to replace the head
and stabilize the top of the cylinder castings .. Or risk egg shaped or tapered bores ..
Old Feb 21, 2021 | 12:37 AM
Louisville Joe
You are right that a stroke increase would probably be easier, but the 7.3L might take a small bore increase.. The pictured block has been cut an inch or so down from the deck, so you are not looking at the actual deck. It's not 100% open.
Louisville Joe
6.2L V8
Jan 25, 2014 02:09 AM
1986FordF150I300
28
Apr 17, 2009 01:58 AM
hollenjoe
Sep 4, 2007 10:25 PM
sparco
May 1, 2005 09:35 PM
wilddog
Dec 1, 2004 09:10 PM
