Weird Sound. Help!
Old Oct 26, 2003 | 01:52 PM
AYoungblood's Avatar
AYoungblood
Question Weird Sound. Help!
Well i did a oil change and i used higher viscosity oil than usual and use Lucas Oil stablizer and now i have a weird sound.
I know what a ping sounds like. Its where you buy cheap cheap gas and when at low RPM or trying to accerlate you can hear little tapping sounds.
Now this might be a "Knock" but what is a knock?
Im not saying it is, what im asking is what this sound COULD be.
Thanks guys,
Adam
Old Oct 26, 2003 | 02:50 PM
jwtaylor's Avatar
jwtaylor
The most accurate way I can describe a knock or detenation is get a glass bottle and put a small rock in it and shake it, that is a detenation knock. IMO. later
Old Oct 26, 2003 | 03:03 PM
AYoungblood
Yeah its not that.
Its a heavy clunking sound. Buts its really fast. (happens a lot so its hard to make out if its a constant sound or just now and then)
It sounds like something is bouncing back and forth inside.
Adam
Old Oct 26, 2003 | 03:14 PM
jwtaylor's Avatar
jwtaylor
When does this occur at idle when hot/cold, up hills, etc. ? Should it happen at idle and or all the time then you can unhook a plug wire one by one and if it stops you have found the cylinder if it is a bearing it will stop completely if it has something to do with a rod then it will get quieter. Let us know
Old Oct 26, 2003 | 05:50 PM
AYoungblood
Ok man, thanks a lot!!
Its 6:30 and its dark here now so i cant look at it now, but tomorrow ill check it out!
Thanks!
Old Oct 27, 2003 | 01:51 PM
90f150moneypit's Avatar
90f150moneypit
Actually, if it stops more than likely it's a wrist pin. If it gets louder it's a bearing.
Knowing if it does it hot/cold or gets worse/better and at what RPM's is very important in diagnosing a knock.
Old Oct 27, 2003 | 03:31 PM
jwtaylor's Avatar
jwtaylor
Appears I got that backwards huh? Well did you figure out anything AYoundBlood?
Old Oct 27, 2003 | 05:32 PM
DanTana's Avatar
DanTana
Get a broomstick and put it against the block while running and put the other end against your ear. If it's an engine knock you can pinpoint it that way.
Old Oct 27, 2003 | 08:09 PM
AYoungblood
With RPM?
No it doesnt, seems to stay the same/ go away over 1000.
JW:
Well, no, i havent tired pulling the boots off 1 by 1.
Im going to look into it tomorrow. I worked all day today and im off at 4:00pm tomorrow, so hopefuly ill get a little time of light.
But if i cant pin point it, im going to do a compression test.
Can any post a link to a "how to" on broncos/5.0's plz.
I assume (as ive read on other engines)
1. unplug all injectors
2. pull all plugs and makes sure to mark all wires and plugs to go back togather (but ill just replace plugs)
3. Attach compression gauge to #1 (1-8)
4. Crank 3 or 4 times.
5. Check and write down.
6. goto step 3
Adam
Old Oct 27, 2003 | 08:23 PM
90f150moneypit
Actually I meant when you pull the plug wire does it get louder.
It goes away with higher RPM? Does it make any difference if it is cold or hot?
I don't think a compression check is needed at this point, unless it's also running poorly.
Could it possibly be a lifter tap?
You can hook up a timing light to any wire while it is running and see if the knock apears to be as fast or slower than the light flashing. This will tell you if it is valvetrain related or bottom end (the valvetrain spins twice as fast as the bottom end).
Old Oct 27, 2003 | 10:53 PM
AYoungblood
It could POSSIBLY be ligter tap, but i hope not.
I gotta buy a timing light SOON!
I wanna also check my timing, and now need to check out this problem.
Thanks guys, ill update you tomorrow.
Adam
Ohh also, no its running GREAT! besides for the common blow by . No probs
Old Oct 27, 2003 | 10:58 PM
AYoungblood
Also I asked this question here: https://www.ford-trucks.com/forums/showthread.php?s=&threadid=156980
Can anyone explain to me how "blow by" and buring oil is different? (as in where is the oil "blowing by" and not going into the chamber?)
Thanks guys,
Adam
Old Oct 28, 2003 | 07:03 AM
jwtaylor's Avatar
jwtaylor
I reread your initial post and thought change your oil back to a 10w-30 and see what happens. I know for a fact that going from 5w-30 to 10w-30 will increase the oil pressure so I would imagine a different oil might cause the weakest link to be more pronounced. I am suspecting a lifter, but I would change the oil just to see what happens, your probably fine. What higher viscosity oil brand and weight did you use? later
Blow by is when the pressure from the combustion chamber leaks past the rings causing excess pressure in the crank case. So it means you have worn rings
burning oil is when the valve seal and guides are worn and the oil leaks down into the combustion chamber and burns.
Old Oct 28, 2003 | 07:28 AM
AYoungblood
Ok thanks JW, thats EXACTLY what i wanted to know.
I went from Mobil 1 10w30 to Mobil 1 15-50. I read some people on this forum said they use thicker oil with a older engine. So i figure i would give it a try. But i guess ill go back to 10-30.
Adam
Old Oct 28, 2003 | 07:34 AM
jwtaylor's Avatar
jwtaylor
Well hopefully this will fix it, let us know, later
alloro
Mar 10, 2017 02:51 AM
adam10
Feb 22, 2012 03:17 PM
Adam0331
40
Aug 31, 2008 09:09 AM
881504x4
Jul 11, 2005 05:27 PM
