Engine stalls with AC on?
Old Oct 23, 2003 | 12:22 PM
farmF-150's Avatar
farmF-150
86 F-150 302 EFI (4spd manual)
Every time I use the AC or Defrost my idle speed goes down to about 400 rpm and struggles. Most the time it cuts off, this almost always happens when I slow down to make a turn and push the clutch in. Also, when I turn my steering wheel sharp at slower speeds 5mph or less the motor cuts off?
I have messed with the timing several times (basically turning the distributor to the left or right) but it doesn't help.
One other thing; the motor wants to cut off when I let out the clutch as well (AC or No AC)?
Any ideas on how to fix this? I know the clutch may be going bad but that wouldn't explain the idle problem.
Thanks!
Old Oct 23, 2003 | 01:30 PM
EPNCSU2006's Avatar
EPNCSU2006
I'm not sure how the 86 EFI system works, but it sounds like whatever bumps the idle speed up is not working. It would be the Idle air bypass solonoid in 87-up trucks, and could be the same thing on your truck, but since I'm not familiar with 86 EFI, I don't know for sure.
Old Oct 23, 2003 | 02:43 PM
87 XLT's Avatar
87 XLT
I agree I would try cleaning the IAC for starters. Any codes?? If the computer cant control the IAC it will give you a code.
Old Oct 23, 2003 | 03:41 PM
farmF-150's Avatar
farmF-150
Thanks, I will try and get a Idle Air bypass solonoid from autozone and see if that works.
Thanks again.
Old Oct 23, 2003 | 03:46 PM
87 XLT's Avatar
87 XLT
Good luck with it.
Old Oct 24, 2003 | 08:28 PM
circledirt's Avatar
circledirt
Factory AC? If so, whenever AC turned on or steering wheel turned increasing ps pressure ecm should bump idle up a bit to compensate for increase in load. Does engine idle up to about 1200 rpm,s when first started and then idle down to about 700? If not do you have to open throttle with foot to start? Sounds like idle motor getting weak. 87 and epnc probably correct.
Old Oct 27, 2003 | 08:02 AM
farmF-150's Avatar
farmF-150
Thanks for the solutions. My truck does have the factory AC and it idles around 1200 when it is first started then goes down to around 600-700 rpms. When I turn on the AC it goes down to about 400-500 and struggles every time the compressor cycles, which is 1 time every 5 seconds.
I got a chance to turn up the idle this weekend which helped a little. It now idles about 900 rpms after it warms up. Although it will still cut off if I turn sharp with the Defrost/AC on high. I wish I could have tried the IAC but I didn't get a chance to go to Autozone this weekend.
Also, what does 87 and epnc correct mean? Sorry, I am a little slow on the wording. If it is the idle motor, then what should I do to fix it, replace it or repair it? Any ideas on how to check or remove etc?
Thanks again for all your help.
Old Oct 27, 2003 | 06:08 PM
DW2455's Avatar
DW2455
you know your not suposed to adjust the idle screw, you probaly have a problem some where else, but just for reference if the throtle body has never been changed, then you shouldn't have to touch the idle screw. I would pull the codes and check things out. good luck DW
Old Oct 27, 2003 | 08:13 PM
AYoungblood's Avatar
AYoungblood
Thanks again.
Try to see what codes you can get 1st.
please!
Old Oct 28, 2003 | 08:10 AM
farmF-150's Avatar
farmF-150
Thanks, I will see if I can get over to Autozone sometime this week and see if they can check the codes for me.
Thanks again
jasindude1
1978 - 1996 Big Bronco
Feb 24, 2017 05:14 PM
jmuenchow
18
Sep 17, 2016 07:41 AM
JH1975
Sep 24, 2015 12:24 AM
85F350IDI
Sep 6, 2015 11:16 PM
Ford12v
May 21, 2014 07:49 AM
