Back up lights
Old Feb 6, 2021 | 07:13 AM
Mike Boutilier's Avatar
Mike Boutilier
Question Back up lights
Hello there, first post here.
I have a 2020 F250 with halogen headlights. I am looking to swap the reverse lights with LED bulbs. I have tried several of the 7440 bulbs and none of them will fit into the socket. The factory bulb has WT21W on it.
Am I missing something?
Thanks!
Boot
Old Feb 6, 2021 | 07:42 AM
Poncho450's Avatar
Poncho450
Thanks!
Boot
I don't know that LED makers have caught up to this yet. I just checked out SuperBright LED's website, which is usually a good reference even if you don't buy there. Their menu goes no higher than the 2019 model year.
I'm pretty sure I swapped out the LED reverse bulbs that I had in my 2019 to my 2020. But it's too cold for me to want to go out to the garage and pull it apart to check. SuperBright is showing a 7440/7443 for 2019.
Old Feb 6, 2021 | 07:47 AM
Mike Boutilier
Thanks. The silly sockets need to go!
Old Feb 6, 2021 | 09:05 AM
Poncho450's Avatar
Poncho450
Wonder why they felt the need to change sockets/bulb numbers between the 2 model years?
Old Feb 6, 2021 | 09:21 AM
Poncho450's Avatar
Poncho450
OK Mike, I checked things out and I'm sorry to say that I mislead you. I've changed so many things over light wise on 2017, 2019 and my current 2020 that I guess I forgot what I did and did not do.
My reverse lights are indeed the incandescent Sylvania WT21W or 3439 bulb. I hadn't changed over to LED. However, I did find the LED's that were in my 2019. They're a pigtail style with a rubber flange around the bulb that will fit into the hole of the lens assembly.
I tried popping one in. I think it would probably work, but I'd like both the base and the rubber flange to be a little more secure so I don't think I'm going to install them.
Old Feb 6, 2021 | 09:24 AM
shawnee1's Avatar
shawnee1
This thread may have some useful information
https://www.ford-trucks.com/forums/1...-to-led-2.html
Old Feb 6, 2021 | 09:25 AM
Mike Boutilier
Probably so we have to buy Ford bulbs?
Old Feb 6, 2021 | 09:29 AM
Poncho450's Avatar
Poncho450
No luck in that thread for '20 or '21 by the look of things. At least not without trimming the base on a 3157. Been down that road with front turn signals in the past. Didn't like it. They worked but I never thought they were secure enough and wrapped the base with electrical tape.
But on the bright side for the front I found a 4257 switchback from GTR Lightning that snapped in beautifully. The search is still on for reverse lights.
Old Feb 6, 2021 | 09:31 AM
Poncho450's Avatar
Poncho450
If you need an incandescent because of a burned out bulb I guess you would have to. As far as LED replacement, which I would do, there doesn't seem to be an option yet. At least not one that I'd be satisfied with.
Old Feb 6, 2021 | 10:19 AM
Mike Boutilier
I also did the trimming thing on the sockets and still had to tape the lights in and that is cheesy IMO. I put very bright LED bars under the bumpers but don't want to have to turn them on in parking lots and places like that.
Old Feb 9, 2021 | 07:07 AM
rprice32's Avatar
rprice32
The same reason Apple changes their iPhone/iPad setups every few years, to keep you true to their parts and keep you buying more of said parts.
Old Feb 9, 2021 | 08:37 AM
MKrenn's Avatar
MKrenn
This bulb works. It is installed in my truck. Only have to trim the ears.
Amazon Amazon
Hope this helps.
Old Feb 9, 2021 | 08:38 AM
MKrenn's Avatar
MKrenn
Amazon Amazon
Old Feb 9, 2021 | 09:00 AM
Great Danes's Avatar
Great Danes
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Hope this helps.
Not to hijack this thread, but did you replace any of the other bulbs like signal, and brakes? if so, what did you end up using?
I think that 3157 bulb from Alla will fit all of the above (obviously, in different colors).
Old Feb 9, 2021 | 09:15 AM
MKrenn's Avatar
MKrenn
I replaced the fog lights with the below bulb:
Amazon Amazon
I left the rest alone especially the headlights. Factory headlights now are way better than they were years ago....
