Image reversed on backup camera
Old Feb 2, 2021 | 04:32 PM
MSF350's Avatar
MSF350
Has anyone had this happen to their backup camera? My sons 2010 F150 Lariat 4x4 is having this problem. Had the dealer look at it and they said they had never seen it before said I just needed to replace the whole camera system.
Old Feb 3, 2021 | 09:55 AM
alloro's Avatar
alloro
Is it an OEM or aftermarket backup system?
Old Feb 3, 2021 | 10:03 AM
MSF350's Avatar
MSF350
Its OEM sony system with 8 inch screen with navigation/sat radio/backup camera
Old Feb 3, 2021 | 10:07 AM
alloro's Avatar
alloro
Make sure the option 'Parking Interrupt' set to OFF.
Old Feb 3, 2021 | 10:09 AM
MSF350's Avatar
MSF350
Okay will do
Old Apr 14, 2021 | 08:36 AM
janalina98's Avatar
janalina98
Having same problem.
where do I locate “parking interrupt”? I have OEM factory camera/radio but backup screen is in rear view mirror.
Old Apr 14, 2021 | 09:48 AM
RLXXI's Avatar
RLXXI
Instrument cluster menu, navigate to settings using the arrow keys on the steering wheel.
Old Apr 14, 2021 | 12:57 PM
gDMJoe's Avatar
gDMJoe
Exclamation
janalina98 ...
(owner's manual) Don't have one -OR- would like a digital, searchable desktop document?
Owner's Manuals ««« -click-
» Select Your Year [ Choose One ]
» Select Your Make [ Choose One ]
» Select Your Model [ Choose One ]
Also ...
HINT/TIP: Put your complete vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, modifications, etc., etc.) in your signature. *Eliminates the need to play 20 questions.
» Edit Signature « *And don't forget to [ save ] it.
Old Oct 4, 2021 | 04:09 PM
TheRedDragon's Avatar
TheRedDragon
2010 to 2015 F series rear camera replacement
For anyone having issues with their 2010 to 2015 F series backup camera, I found a relatively cheap solution....at least cheaper that the $680 charged by a dealership. I previously tried various solutions on the web including fuse reset, turning parking lines off then on, etc. Intermittently the camera would say it couldn't be found, brighten, reverse the image and other weird things. Ultimately I ordered this new Dorman camera off Amazon for about $90 and replaced it in less than 10 mins. The OEM part I replaced was ec3t-19g490-aa. When I mounted the new camera the image was upside down because it is made for a different model. I just mounted it the opposite direction in the holder and adjusted the clip location to make it work.
Dorman 592-017 Rear Park Assist Camera for Select Lincoln Models
Amazon Amazon
Old Jun 8, 2022 | 11:32 AM
Prez23's Avatar
Prez23
1st Gear
My back up camera is doing the same thing. I see your post on the form is from 2021 were you able to fix the reverse image issue? If so how did you do it?
Thanks Mark
Old Jun 8, 2022 | 08:56 PM
gDMJoe's Avatar
gDMJoe
Exclamation
Prez23 - My back up camera is doing the same thing. I see your post on the form is from 2021 were you able to fix the reverse image issue? If so how did you do it?
Following the thread... The fix is either in posts 4-7 (setting Parking Interrupt to -OFF-) -OR- post 9 (buying a new camera).
Vehicle Information *Telepathic or Carnac we're not.
If you're not going to provide the vehicle information in your post(s), consider putting your complete vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, maintenance, modifications, etc., etc.) in your signature to have it automagically included when you post. *Eliminates playing 20 questions when/if a post is made pertaining to your vehicle.
» Edit Signature ««« -click-
*Don't forget to [ save ] it.
Old Jun 20, 2022 | 05:24 PM
HomerWinzlow's Avatar
HomerWinzlow
Thanks Mark
It is a software malfunction in the camera. Replace the camera and have the camera initialized by the dealer.
UncleDooly34
2015 - 2020 F150
Dec 6, 2017 03:27 PM
drakethegreat
6.4L Power Stroke Diesel
Nov 4, 2010 12:38 PM
DanzbigA250
Sep 9, 2009 09:08 PM
RhinoScores
General Automotive Discussion
13
Apr 28, 2007 08:30 AM
