4.6 oil consumption
Old Oct 26, 2003 | 11:14 AM
1BigExpy's Avatar
1BigExpy
4.6 oil consumption
My 2000 expy with a 4.6 is using oil. On a 250 mile highway drive it will drop about a third of a quart. It runs fine, sounds fine, and the garage floor isn't covered in oil. I haven't noticed any smoke from the exhaust either. Any ideas on whats going on.
Rob
Old Oct 26, 2003 | 06:29 PM
tsdrallyer's Avatar
tsdrallyer
How many miles on your vehicle? What speeds do you drive? Are you towing? What weight oil do you use?
If your answers are: less than 200K miles, not towing, legal speeds and factory recommended 5w30 oil is used, replace your pcv valve and see it that doesn't improve the oil consumption. If your crankcase, valve covers can't breath properly pressure will build up and create more blow by.
Old Oct 28, 2003 | 05:04 PM
1BigExpy's Avatar
1BigExpy
I only have 44000 miles. 5w30 is the only oil I use and its changed every 4000 miles. After a trip from CA to TX I noticed it starting to use oil. Is the PCV valve an easy change?
Old Oct 29, 2003 | 04:36 PM
southprk's Avatar
southprk
pcv valve is very easy to change.. a few people on this board compiled a great resource..
http://home.cinci.rr.com/domination/expedition/eog.pdf - complete instructions available there.
MrBonez
Modular V8 (4.6L, 5.4L)
Mar 4, 2017 06:39 PM
eldorable
1997 - 2003 F150
May 10, 2015 10:01 AM
ebraunusa
18
Dec 14, 2010 11:20 AM
KAHNE9
1997 - 2003 F150
17
Jan 2, 2010 07:38 PM
MC04
Mar 13, 2004 07:52 PM
