Warm Engine will not start
Old Jan 31, 2021 | 01:55 PM
JOSHfrompa's Avatar
JOSHfrompa
Angry Warm Engine will not start
I have been battling a frustrating problem with my F250 2011 F250 6.7 Diesel for over two months. The problem is that the truck will start up when the the engine is cold and run with no issues. When I shut off the engine after driving for 15 minutes or more, IT WILL NOT START. NOTHING happens when I turn the key. If I wait about 10 to 15 minutes to cool down the engine. It will start. The FORD Dealer gave it a complete diagnostic and replaced the ignition switch. I was charged $536.00 and I still I have the problem. I'm reluctantly bringing it back to the FORD Dealer, however, I do not believe they can fix the problem. In addition, a previous mechanic tested both batteries, replaced the starter motor and "cleaned the connections".
I'm frustrated and would appreciate any suggestions.
Old Jan 31, 2021 | 03:34 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
See what you can find out with FORScan.
Old Jan 31, 2021 | 05:19 PM
Just Strokin's Avatar
Just Strokin
Since you still have the problem, I would take it back and have them to insure you they fixed the problem. You have paid for the repair, let them make sure the repair fixed it.
Old Feb 1, 2021 | 07:22 AM
JOSHfrompa's Avatar
JOSHfrompa
THX for the advice. I was searching to see if anyone in the forum had a similar problem.
Old Feb 1, 2021 | 09:07 AM
The Bone's Avatar
The Bone
they charged you a butt load of cash only to not solve the problem. Tell them not just throw parts at it. You can do that thats why you are here.
Do you use the parking brake? There have been lots of issues with the connector that is next to the brake peddle.
Old Feb 1, 2021 | 09:12 AM
JOSHfrompa's Avatar
JOSHfrompa
THX, I'll take a look after the snow let's up, however, I do not use the parking brake. I have a service visit with the FORD Dealer tomorrow.
Old Feb 1, 2021 | 04:18 PM
speakerfritz's Avatar
speakerfritz
is the vehicle stock
how long have you had this truck
how long has the problem been going on
Old Feb 2, 2021 | 08:15 AM
JOSHfrompa's Avatar
JOSHfrompa
I purchased it new in 2011. It is stock and the problem started about 2 months ago. It has 190,000 miles. Before the ignition switch was replaced the radio was not working. After the switch was replaced the radio is working fine. It could be a lose wire????
Old Feb 2, 2021 | 08:25 AM
speakerfritz
Since you said it does nothing ....I think that will rule out block temp sensor or air intake sensor
I would move the steering wheel position slightly and. Could verify your loose wire theory .
Old Feb 2, 2021 | 10:06 AM
JOSHfrompa's Avatar
JOSHfrompa
Thanks for your thoughts. I had the same thought about the steering wheel position or not going completely in PARK, however, jiggling the steering wheel or gear lever did not help. If I go outside right now, the truck will start, so the problem is ...not starting after it has been running for over 15 minutes. If I run it for 5 minutes, then shut it off, it will restart.
I will post the DEALERS fix. if they can fix it.
Old Feb 2, 2021 | 11:22 AM
jetskier's Avatar
jetskier
What about trying to start it in neutral?
Old Feb 2, 2021 | 11:58 AM
JOSHfrompa's Avatar
JOSHfrompa
If I leave the truck in neutral, I'm not able to remove the key.
Old Feb 2, 2021 | 05:44 PM
The Bone's Avatar
The Bone
Does your truck have remote start? If it does have you tried to use that?
Old Feb 2, 2021 | 05:45 PM
JOSHfrompa's Avatar
JOSHfrompa
No remote start. Thanks for your interest.
Old Feb 3, 2021 | 04:14 PM
The Bone's Avatar
The Bone
Another thing I had happen to me was a fuseable would get hot and then it would for a lack of a better term become unhooked. You couldnt see it but I would wiggle it around and bingo. Another thing it could be is the starter relay in the fuse box. There is very little 12 volts inside the cab anymore. Everything is run off relays. You could swap out the starter relay for another one in the box to see if that is the problem. Just remember which relay you swapped out. LOL
