HID Lights Tech Support
Old Jan 30, 2021 | 02:51 PM
Walleye Hunter's Avatar
Walleye Hunter
My truck came with HID headlights and now they are giving me trouble. I have narrowed it down to the passenger's side transformer. I am unable to find any mfg's information on the thing so I am looking for insight on what to do with it. I wouldn't object to just putting regular headlamps in if I could do that. Alternatively, I have the front end off of an '01 out there that I could install, complete with its headlights. What are my options here? Right now the transformer is blowing fuses.
And through this process, my high beams have ceased to function, what could cause that?
Old Jan 30, 2021 | 03:46 PM
Shovelheadrob's Avatar
Shovelheadrob
Try asking Retrofit source, they are suppliers of quality hid conversions.
www.theretrofitsource.com
Old Jan 30, 2021 | 03:52 PM
Walleye Hunter
Nice selection there, I can give them a call. It also looks like I could just use regular bulbs and remove the ballasts. I'll check NAPA tomorrow and see what the bulbs and their connectors look like.
And now to figure out whey the high beams crapped out.
Old Jan 30, 2021 | 04:10 PM
Shovelheadrob
Mark, do you know what brand they are? I had one of my Morimoto projectors go out, it was just a bulb failure, the transformers are still fine. I bought a few spares from a reputable UK supplier (I also went down a couple of K on the output) as it was much cheaper than getting replacements from Retrofit source for me.
Old Jan 30, 2021 | 05:28 PM
Walleye Hunter
Nope, there are no mfg's markings, at least not on the outside. I think the tag indicates that the bulbs are 35W. We have snow coming and it's my plow truck so I'll have to figure something out tomorrow. I'll see if I can find anything. And mfg might not even matter, it looks like the connectors are all the same.
Old Jan 30, 2021 | 05:50 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Mark, check DDM as a possible source for the HID equipment you are attempting to repair/replace. They were big in the aftermarket HID scene years ago. I installed their kit into a motorcycle with a projector housing I had.
As long as the wattage rating and connections are the same, it should not matter who put a sticker on the transformer.
Old Jan 31, 2021 | 08:56 AM
Walleye Hunter
So...for now I bypassed the transformers or ballasts or whatever they are and put in regular lights. Now I have a good understanding on where those wires come from and go to, it was always just a confusing bird's nest in that vicinity.
Next up is the ceasing to function of the high beams. I did learn (if I didn't already know) that the left and right headlights have their own fused circuit but the short in the ballast must have blown something in the high beam circuit and I'm stuck on low beams (things could be worse). So...is there a relay for the high beams somewhere or did the multi-function switch take a hit? Or something else?
Old Jan 31, 2021 | 10:23 AM
Shovelheadrob
This may help, it may not....my HID projectors have a single filament bulb, the projector has a mechanical shutter which is controlled by the operation of the high beam circuit, no power = shutter closed, dip beam, high beam power on = shutter open, high beam. I've never had to investigate the exact operation of this, but assume it could fail as it's an electromechanical device.
Old Jan 31, 2021 | 03:58 PM
Walleye Hunter
I got it, fuse 16 under the dash-high beams. We're back in business here.
cuda66
Sep 15, 2013 12:52 PM
kc0stp
Jan 26, 2013 09:48 PM
sens1fan
2009 - 2014 F150
Jun 15, 2011 05:47 AM
jaye
Jan 21, 2011 04:33 PM
josh04hdf250
Aftermarket Products
Dec 27, 2010 06:05 PM
