window washer leaking
Old Jan 30, 2021 | 01:16 PM
cullenkyla's Avatar
cullenkyla
Only leaks when it very cold. There will be washer fluid leaking in front of the passenger side of the truck. I believe I saw a tread about this but could not find it . Has anyone eles had this happen to them? thanks
Old Jan 30, 2021 | 01:41 PM
muhford's Avatar
muhford
The pump just pushes into the reservoir with a grommet. Try replacing the grommet first. If that doesn't fix it the pump could be cracked and leaking.
Old Jan 30, 2021 | 02:33 PM
SpencerPJ's Avatar
SpencerPJ
If this is your 2010 in your signature, chances are the rubber is getting old and the cold takes the elasticity away, and it leaks. Replace it, I doubt you can find a grommet only, I don't know. Or pull it clean it, a silicone that sucker in place.
Old Jan 30, 2021 | 09:20 PM
cullenkyla's Avatar
cullenkyla
No its a 2018 diesel KR. Taking it in for a headlight replacement Monday will have them look at the washer again. Thanks
Old Feb 17, 2021 | 05:28 PM
cullenkyla's Avatar
cullenkyla
The leak I though I had was the camera washer lol, It was running down the bumper making it look like a leak.
Old Feb 15, 2022 | 02:46 PM
Stevec_65's Avatar
Stevec_65
There is a Technical Service Bulletin 20-2267 regarding leaking front washer jet
ZombieSlayer
1978 - 1996 Big Bronco
Feb 11, 2015 10:11 PM
stroker04
Jan 13, 2007 06:55 AM
gorimi
1997 - 2003 F150
Nov 13, 2005 05:38 PM
Cape Guy
1997 - 2003 F150
Oct 30, 2004 10:38 AM
mendeldl
Aerostar
Jul 12, 2004 12:51 PM
