I am new to the whole manual locking and auto locking deal of your front wheels.
we had snow the other day so I threw it into 4h and pulled out on the **** to lock in the front. The symbol came up on my dash but anytime I went over 25mph it went away. The 4h stayed lit up the entire time though.
is this normal or do I need to take it into the shop?
my truck is a 18 f350 6.7l crew cab with 30k miles if that makes any difference.
Pulling out the 4wd **** locks the rear diff. It automatically unlocks around 25mph. It is also incredibly hard on it using it while turning, especially in 4wd. This has nothing to do with locking front hubs.
The above is 100% spot on. Pulling the **** away from the dash activates the electronic locker on the rear diff. This locks the rear wheels together. As they cannot spin at different speeds (The outside tire must rotate faster to make a turn as it takes a longer track), it is very hard of the system to make turns with this engaged, thus it should only be used in a straight line. This feature can be used in 2H, 4H or 4L, and is designed automatically turn disengage at 25MPH as you have seen.
The front is locked in (auto hubs locked in) when the switch is rotated to either 4H or 4L. Pulling out the switch locks the rear differential. A totally different thing. Please read the Owner's Manual on the proper operation of both features. As a newbie you need to understand how the systems work rather then just taking a stab at it.
When I would use the rear locker is on a hill that was snow covered to get up it when I had to stop at the bottom. Even with 4wd my older F150 had issues until I locked it in.
If you are sitting there spinning in 4wd and can go straight then engage it to get you moving, as soon as you can disengage it.
Driving on slippery roads with the elocker on is extremely dangerous and could cause loss of control.
It will not let you steer your truck away from other cars or bridge pillars.
One thing I've been trying to figure out is if the Electronic Locking Rear Axle is limited slip when not locked. Anyone know if there's any mechanical LSD as well? Or is 'slip' just managed by the Traction Control System when not locked?
LoL
Yes, it can cause the rear end to kick out if you are not used to it, but to say it won't let you steer is quite the tall tale.
There's a few intersections on my way to work where I engage the locker if it's wet (turning right on red). Otherwise, my truck will just spin the inside tire, then the truck will do it's stupid traction control crap....meanwhile, I'm a sitting duck with traffic coming up on me at 50mph.
I just kill ABS/TC system, engage locker, and hammer down! (I have my locker on an upfitter switch, so it doesn't abide by the 25mph rule. I also have my ABS/TC circuit on an upfitter so I can disengage it)
Only the front locker in my Rubicon effects steering.....greatly.
Lockers should only be used in low traction situations but makes a significant difference when stuck.
Some of the comments here and actual use that I have witnessed are why I steer away (pun intended) from buying used vehicles with specialized systems or features.
Either you are prone to hyperbole or just misinformed.
