Hard and long to start
Old Jan 26, 2021 | 11:24 AM
Heavy hual guy's Avatar
Heavy hual guy
I have a 1988 f250 7.3idi and it is having a very hard time starting every day. I have put in new glowplugs. A new glowplugs relay and controller. And I have a facet lift pump mount up under the frame but still running with the factory mechanical pump. I go to leave everyday for work after school at 2.45 and it will never pop off. I start for 15 seconds at a time and I can do that 3 times before the batterys become to week. Then I get Jumpstart by my dad and still takes another 2 15 second starts and finally pops off. My boss told me to get up this morning and start it and then not touch it tell I have to go to work. And I am siting here this morning and it just cranks tell the batterys run dead. So im usually s.o.l everyday and need help to figure out this issue
Old Jan 26, 2021 | 12:10 PM
Olds64's Avatar
Olds64
When the truck finally starts does it spit white smoke? You could have an air intrusion issue. Depress the schraeder valve at the fuel filter while a buddy cranks the engine. You should get a solid stream of fuel from the schraeder valve. If it still has trouble starting you can bleed the injector lines with the truck running. Just loosen 1 at a time until they start to spit fuel and then tighten them again. Good luck.
Old Jan 26, 2021 | 01:57 PM
DarkOverCast's Avatar
DarkOverCast
Sounds like your batteries or starter is weak if all you get is three 15 second crank cycles.
I'd get the batteries tested, clean every connection, then if that doesn't fix it swap the starter out.
Old Jan 26, 2021 | 02:32 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
yep, that be my first guess too.
Old Jan 26, 2021 | 04:12 PM
Heavy hual guy
I'd get the batteries tested, clean every connection, then if that doesn't fix it swap the starter out.[/QUOTE]
I did get new batteries last year when I started driving this thing. But my dad was saying it's about normal for him to 3 cranks out of it. And we are thinking about the starter probably needing replaced. Is there any else on the motor or electricaly I could check or replace. Also I noticed before I changed my glow plug controller the wait to stat light would come on for about 10 seconds then shut off then the relay would start clicking. But now with the new one its only one for about 4 seconds then the light goes out and starts to click. And then I would try to cycle the plugs a 2nd time then the light would only be on for 2 or so seconds then kick off and click. And idk is it supposed to be like that or if I should switch back to my only controller or I dont know
Old Jan 27, 2021 | 07:28 AM
tjc transport's Avatar
tjc transport
i ain't rite
you have a problem with the glow plug circuit.
4 seconds wait to start light is the hint.
it should be closer to 15 seconds.
what brand glow plugs did you put in it?
motorcraft ZD-9 glow plugs ONLY in these engines.
Old Jan 27, 2021 | 05:40 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
This could be true too ...just arbitrarily replacing things does not always fix issues ... see my Glow Plug Guide ... see POST #3 https://www.ford-trucks.com/forums/1...-the-cold.html
Old Jan 29, 2021 | 10:05 AM
15W-40's Avatar
15W-40
Yes, please verify the glow plugs. My truck had new glow plugs according to the previous owner. I had similar problems to you. Took them out and found they were Autolites.
The glow plugs are easy to test. Connect a test light to your positive battery terminal and then touch the top of each plug. The light should glow. There's also a resistance test but I didn't have to go that far to know I had a problem.
I now have new Motorcraft ZD-9's and it cold starts like a champ.
Old Jan 29, 2021 | 10:21 AM
hobohilton's Avatar
hobohilton
Are you plugging in the block heater at night ?
Hobo
welder42
Sep 19, 2019 10:00 PM
Golden Helmet
21
Sep 29, 2013 10:09 AM
Randle
Nov 5, 2012 05:37 PM
yungun
1997 - 2003 F150
Nov 9, 2011 09:25 PM
trucking87
May 13, 2005 09:44 AM
