hard to start
Old May 11, 2005 | 10:03 AM
trucking87's Avatar
trucking87
hard to start
I have a 1989 F-250 that has 84000 miles on it. When you start it in the morning it will start right up like it is always has and you drive it 15 t0 20 miles and shut it off it will fire right back up but let it set a hour it fails to start . Than you leave it set 4 to 5 hours it starts like it suppose to again . Any sugestion on what it might be . Thanks for any help in advance
thanks again
trucking87
Old May 11, 2005 | 03:49 PM
jboard's Avatar
jboard
Hi, I had the same problem with my truck when I got it Turned out to be the injector pump was wore out. With the new IP it cranks over better than ever no natter hou long it sits after running.
Her is a link for a good online parts like IPs www.mwfi.com
Hope it helps, Jeremy
Old May 11, 2005 | 04:09 PM
351M's Avatar
351M
I had that problem and I actually changed the pump and for some reason it still did it but after about 2 days of that it started to act normal again.
Old May 13, 2005 | 09:44 AM
pnose's Avatar
pnose
Classic sign of ip goin south.
