abs brakes
Old Jan 26, 2021 | 08:58 AM
lomesome1's Avatar
lomesome1
Question abs brakes
If I put disc brake kit rear axle of my 1993 f150 will the anti lock still work?
Old Jan 26, 2021 | 10:48 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Yes. The RABS tone ring and speed sensor are in the differential.
Old Jan 26, 2021 | 10:56 AM
rla2005's Avatar
rla2005
In theory it should. How well it works is another story, but should be fine. Many folks that I see converted to rear disk brakes eliminate the RABS system then install an aftermarket adjustable proportioning valve.
Old Jan 26, 2021 | 11:30 AM
My4Fordtrucks
The abs system wouldn’t know that you changed the brakes from drum to disk. I believe you would still have to do something about the residual valve on the master cylinder which is set up for disk/ drum brakes.
Old Jan 26, 2021 | 04:56 PM
rla2005's Avatar
rla2005
That's why I stated in theory you should be fine.
X2... No need for the residual valve when using rear discs.
Old Jan 26, 2021 | 07:49 PM
lomesome1's Avatar
lomesome1
How about a residual valve from a model that came with 4 wheel disc?
Old Jan 26, 2021 | 09:20 PM
rla2005's Avatar
rla2005
They do not have one. That's the point.
kentuckydiesel
1997 - 2003 F150
Jan 20, 2006 05:50 AM
vancouverpower
Jan 26, 2005 05:19 PM
52xmax
Jan 11, 2005 07:52 AM
DaBigTow
Sep 15, 2004 06:37 PM
Greg250
Feb 26, 2004 01:56 PM
