ABS or not?
Old Jan 10, 2005 | 05:27 PM
52xmax's Avatar
52xmax
Exclamation ABS or not?
92 f150 4.9. Front disk and rear abs drum brakes.
Had brakes redone at dealer. Told abs module is gone. Big $$$ just for rebuilt one. I pulled the fuse on the abs thinking that brakes would be fine anyway.
Brakes are very sensitive and front brakes lock with almost no braking in the rear.
Is there an adjustment for the pressure for the system?
Thanks
Old Jan 10, 2005 | 11:31 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Run some searches and study some, you may not need an expensive repair and ABS is great when it works.
Go to advanced search and use ABS and my user name.
Old Jan 10, 2005 | 11:42 PM
Popa Tim's Avatar
Popa Tim
That certainly doesn't sound right. Pull a drum and check their work and blled the brakes. They should work normally as ABS only kicks in under heavy braking on dry pavement and it doesn't sound like your driving like a madman....
Old Jan 11, 2005 | 07:52 AM
52xmax's Avatar
52xmax
Thanks for the info. Much appreciated.
