Injector wiring help!
Old Jan 26, 2021 | 12:16 AM
k98311's Avatar
k98311
4wd High
Hey guys,
so im part way into my diy ecu build and im currently looking into how to wire the injectors. After looking at a haynes shop manual pdf i have and looking at some wiring diagrams i found our trucks run on 2 bank systems. so my issue is on the haynes it says one bank is 1 4 5 8 and the other 2 3 6 7 THEN while looking on this forum and on megasquirt it says one bank is 2 3 5 8 and the other 1 6 7 4. Which is correct?? my other question is my diy ecu has more injector outputs so i can tie them into pairs. so should i put them in pairs? and which ones in what order if so? or is just running 2 banks normal and okay. i don't think running them in pairs would have any benefits or power gains. right?
thanks in advance
1990 f150 351w e4od
Old Jan 26, 2021 | 07:21 AM
rla2005's Avatar
rla2005
Every Ford EVTM I have shows the Speed Density injectors are fired 1,4,5,8 then 2,3,6,7
I see no reason to try firing them in pairs. I do believe there was s single model year there was sequential Speed Density used on the Mustang. Again, no reason to go there IMHO.
HooksToy
1978 - 1996 Big Bronco
Oct 23, 2015 07:22 PM
SpringerPop
Nov 20, 2013 08:07 PM
merlynr
Aerostar
May 19, 2009 01:18 AM
Homelessduck
1983 - 2012 Ranger & B-Series
Jun 16, 2008 05:30 PM
Ken460
Oct 21, 2007 10:13 PM
