Fuel tank relocation
Old Jan 25, 2021 | 09:31 PM
chiefdave's Avatar
chiefdave
Ready to start my under bed tank install and looking for advice from someone who has done it. I got the 17 gallon tank kit from CJ Pony. No instructions but basic install looks straight forward.
1. how did you route the fuel line and did you use flexable or rigid tubing?
2. how did you route the wire for the sending unit?
3. did the mechanical fuel pump work OK or did you add an electric pump?
Thanks in advance for any suggestions.
Old Jan 25, 2021 | 11:27 PM
resonateur's Avatar
resonateur
Chief:
Only what I did....others probably have suggestions that are easier. Plus, I have FI, so an in-tank pump was used.
1. I used 3/8" rigid tubing and bent my own lines from the tank to the FI, plus a return line. All double-flare fittings.
2. Ran the sending unit wire, joined the tail light harness and wrapped in new split-mesh wring loom. With the tail lamp enters through the firewall under the dash to the gauge.
3. Electric in-tank pump.
Good luck.
Old Jan 26, 2021 | 03:17 PM
daveengelson's Avatar
daveengelson
Topic has come up on a number of occasions. Suggest going to the search menu, tab down to 'advance search' and enter topic: " relocating fuel tank' or something similar, then narrow search to the 61-66 forum.
1 link under advance search:
https://www.ford-trucks.com/forums/s...rchid=31272689
Posting link to couple threads may find helpful, and/or provide food for thought??
https://www.ford-trucks.com/forums/1632963-fuel-tank-relocation.html
Personally, I would not place a fuel inlet in the bed, there are a # of alternatives depending upon one's refab skills.
https://www.ford-trucks.com/forums/1...-gas-tank.html
F460bigbore
Aug 25, 2018 10:04 PM
jomoflymo
15
Aug 11, 2014 12:41 PM
Ratherbeefishin
Apr 13, 2014 09:24 PM
Tedybear
38
Dec 19, 2007 11:34 AM
Jacques
Apr 6, 2005 09:31 AM
