Ok so I need some help. I am redoing my 56 cab over dump truck. It's a c750 with the lincoln y block 302 in it. I am rebuilding the heads and need the rocker shafts as one of mine broke. Parts are exceptionally hard to find so any assistance would be appreciated.
That is a rare bird...1956-63 production in the big trucks. I have had rocker shafts machined to spec for me in the past, you may have better luck having a shop machine a pair for you instead of trying to locate some for sale.
Edit:
I re-read your post and it looks like you need the shaft not the rocker itself. Here's a complete set. Lincoln 317, 341, 368 are all common to the 302 and 332 truck engines. The big difference is in the lifters and cam drive.
That was what I was thinking, probably cheaper too.
Edit:
Ok thank you, I was trying to do it as cheap as possible because I am going to put a 12v cummins in it next winter just try to get through this summer with it. Thanks for the info though I may get them while I have it all apart.
