It look a lot like a bigger truck Ford bumper but it is a little narrow, isn't it.
Abe,
I was thinking the same thing. Looks nice still. Nice Ford COE bumpers are hard to find. Welcome to the group and please keep us posted on your progress.
Thanks, Ken.
I believe the kit you'll need is the 1282 for the stock style distributor.
I have a Lincoln 317 that I replaced the distributor with a Cardone 30-2808 spec'd for a newer Ford Y Block. When upgrading the distributor the drive gear needed to get swapped with the Lincoln drive gear and the the oil pump was changed to a hex shaft instead of the slot and tang. In this case I used the Pertronix 1281 to fit the newer distributor.
So I got the engine dropped back in the truck and had it running for a little bit today. Found that I have a pretty big leak in the carb. I thought I had found a rebuild kit for it a while ago but having trouble locating one again. Can anyone help me out?
