O4 expy starting issue
Old Jan 25, 2021 | 08:57 AM
gogreenwave's Avatar
gogreenwave
Hello I have an 04 expedition with about 160k miles. Lately I have been having a starting issue. About half the time I turn the key, and it cranks but the engine won't turn over. I have to keep cranking or cranking it 2 or 2 times for the engine to turn over. It then runs fine. This started happening occasionally but now it is happening more and more frequently. What are the most likely culprits that I should investigate first?
thanksMatt
Old Jan 25, 2021 | 10:43 AM
alloro's Avatar
alloro
Try this...turn the key on and wait a few second, then off, repeat two more times then try and start it. If it starts right up the check valve in the fuel pump is leaking which is allowing the fuel pressure to bleed off as the vehicle sits.
Old Jan 25, 2021 | 05:49 PM
Hamfisted's Avatar
Hamfisted
Yeah, like Alloro said. Turn the key from OFF to ON a few times before you try to actually crank the motor. Check valve failure is common anytime after 150k miles. Have to drop the fuel tank to change the fuel pump out.
2004 Expedition Fuel Pumps at Rock Auto
Old Jan 26, 2021 | 04:56 AM
broncoholic's Avatar
broncoholic
I had the same issue a little over a year ago and Hamfisted was there with the same advice. I borrowed a fuel pressure tester from Autozone to confirm it. Here's my thread: https://www.ford-trucks.com/forums/1...ey-on-off.html
I replaced my pump with a genuine Motorcraft pump ordered from a dealership online with the best price I could find. This is a job you only want to do once!
PUREAPPEARANCE
Mar 4, 2011 03:30 PM
carlsson01
Mar 28, 2009 05:43 AM
oahuobx
Nov 25, 2003 10:26 PM
