Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Timing Belt replacement
Old Jan 23, 2021 | 05:54 PM
clintbonnie's Avatar
clintbonnie
So according my internet research, they recommend changing out the Timing Belt between 60K and 100K on my 1.6L 2015 Ecoboost.. Have any of you done this and what did it cost to do it ? I understand this is a "interference" type engine.. so if the belt breaks, it could destroy the engine...
Here is my source :
Does A Ford Escape Have A Timing Belt Or Timing Chain? (autopadre.com)
Old Jun 25, 2021 | 01:56 PM
clintbonnie
Any thoughts or info on this subject ??
Old Jun 25, 2021 | 03:41 PM
ford390gashog's Avatar
ford390gashog
Replace the belt at the factory 150k interval. The cost is about 700.00.
Old Jun 27, 2021 | 10:39 PM
m-chan68's Avatar
m-chan68
As dealership tech who has replaced many timing belts in my career, I say replace it sooner than later. And while you're in there, change the water pump as well. Although the water pump on this engine is not driven by the timing belt, it does require belt removal to access and replace. Also, water pump failures are relatively common on this engine at higher mileage.
Old Jun 28, 2021 | 09:57 AM
clintbonnie
Hey thx for the info.. sounds like a good plan..
jmms
Aug 20, 2007 03:41 PM
fordguy76
General Automotive Discussion
Nov 23, 2006 07:15 PM
thefarelaneman
Nov 20, 2006 09:57 PM
fordtuffman
1983 - 2012 Ranger & B-Series
Jun 14, 2004 07:04 PM
Ken00
May 7, 2002 09:21 AM
