Hubs not disengaging
Old Jan 23, 2021 | 04:43 PM
Dweber85rc's Avatar
Dweber85rc
Before I rebuilt my front axles this summer and replaced all the hub seals I had disconnected the vacuum lines at the ESOF solenoid since they leaked and I would have to manually lock the hubs anyways. Today I decided to give it a try since I hadn't tried and hooked it back up. The hubs locked instantly but would not unlock without releasing vacuum. I drove a couple of miles, backed up a while and they stayed locked until I disconnected the vacuum line at the solenoid and they unlocked instantly. I did some searching and this would lead me to believe that the vacuum solenoid on the passenger fender is probably not working right. Does that sound about right? All the hub seals are new and since they locked I think I can assume that there are no vacuum leaks so about all it could be would be the solenoid I would think?
Old Jan 23, 2021 | 05:36 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
Probably the problem, they crack on the bottom of the switch. I changed mine for 35 bucks That switch also controls the air flow in the vents, mine worked intermittently until I replaced it
Old Jan 23, 2021 | 10:23 PM
DSMMH's Avatar
DSMMH
Here is how to check the ESOF solenoid. At the ESOF solenoid, disconnect the vacuum line that goes to the hubs. Connect a vacuum gage where you disconnected the hub vacuum line. Start the engine. You should be able to select 4WD on the dash switch and you should see vacuum. Deselect the 4WD and the gage should go to zero. If not, the solenoid is sticking and needs to be replaced.
Ed
Old Jan 24, 2021 | 06:06 AM
DavenTn's Avatar
DavenTn
The solenoid has a small foam filter in it that deteriorates and gets clogged. It's really not worth fixing since they're pretty cheap... but just in case.
Old Jan 24, 2021 | 12:52 PM
Teal69's Avatar
Teal69
Ed
To add to what Ed said, the solenoid (PVHS or Pulsed Vacuum Hublock Solenoid) acts like a click type pen, one click to engage and another to disengage.
A while back I copied this from a thread somewhere.
You can verify the function of the PVHS by connecting a vacuum gauge to the vacuum line from the PVHS which goes down to the hubs behind the passenger side inner fender. Leave the line to the hubs disconnected for the test. (I connect at the factory splice which is right beside the vacuum reservoir.) When you turn the switch to 4HI you will see full vacuum for 30-45 seconds. When you switch it back to 2WD you will see reduced vacuum (about 7 in/hg) for a slightly longer period of time.
Old Jan 24, 2021 | 04:36 PM
2002Ex's Avatar
2002Ex
My solenoid was shot too. Even the heater controls are affected by it, if you have the push button control style. Replaced mine and the heater controls are good, but my hubs still won't engage from the switch, the transfer case switch works, but not the vac lines. I assume it is the hub seals.
The solenoid is cheap and easy to replace. RockAuto for example.
Old Jan 24, 2021 | 04:45 PM
Teal69's Avatar
Teal69
Ed
To add to what Ed said, the solenoid (PVHS or Pulsed Vacuum Hublock Solenoid) acts like a click type pen. One click to engage and one click to disengage.
Old Jan 29, 2021 | 02:45 PM
Dweber85rc's Avatar
Dweber85rc
Just wanted to report back. New vacuum switch was the ticket.
Old Jan 29, 2021 | 06:30 PM
Vinny G-the EX man
That’s great, glad we were able to help!!
Old Jan 30, 2021 | 01:02 PM
2002Ex's Avatar
2002Ex
Good news!
Old Feb 1, 2021 | 06:44 AM
DavenTn's Avatar
DavenTn
Thanks for reporting back... helps everyone.
Old Apr 23, 2024 | 03:32 PM
twobelugas's Avatar
twobelugas
oops, wrong thread from fatfingering and clicking on the "suggested threads"
jimjokjv
Oct 5, 2018 05:02 PM
254XP3
Dec 13, 2017 08:14 AM
allenhillview
Apr 30, 2016 09:59 AM
Younork
Feb 17, 2012 09:28 PM
nitro3421
Feb 4, 2011 07:16 PM
