Speed cluster Problem
Old Jan 22, 2021 | 03:19 PM
Jacobrivest's Avatar
Jacobrivest
Trailering
Hi, I own a F100 1979 since a few years. At first, did not have much problem with knowing my speed with the cluster everything worked fine. Then I decided to change my transmission pan seal because it had some used and changed the cluster (from a ford bronco same year) because their was some feature that didn't work . Since then, I've noticed it takes a lot of time to know the speed from the cluster. Il changed the cluster speed cable connected to the transmission pan but it didn't change anything. I'm wondering what the problem could be. I've notice that when the car get hot enough, the cluster started to work but in low speed (0 to 60) the needle is moving and can't tell the correct speed. I've put some Formule F transmission fluid as recommanded . The level of fluid seams fine. Any idea? thanks
Jack
Old Jan 22, 2021 | 03:37 PM
scottscott's Avatar
scottscott
The speedo head in the cluster you installed is bad. Remove the cluster, take it apart, & swap the old speedo head in.
Old Jan 24, 2021 | 08:16 PM
Ozzie H.'s Avatar
Ozzie H.
Take a look at the transmission dipstick to see the correct fluid to use. I thought that they changed from type F prior to 1979.
Old Jan 25, 2021 | 10:38 AM
HoustonDave's Avatar
HoustonDave
Two things could be wrong, the speedo driven gear in the tranny could have failed or the speedo head is bad. Disconnect the cable from the speedo head behind the dash and drive the truck a bit...does the cable turn as you drive? If you try holding onto the square end does it turn in your hand or can you stop it with your fingers? If no turns or turns jerkily/weakly, you may need a new speedo driven gear at the trans (easy fix.) If the cable turns solidly, you probably inherited a bad head unit and should swap your old unit back in.
Ozzie makes a good point... Ford changed to a Dexron type fluid in '76 (I think) - read your dipstick and use what it says to use.
Old Apr 10, 2021 | 04:04 PM
Jacobrivest
Trailering
thanks a lot!
Old Apr 10, 2021 | 06:55 PM
matthewq4b's Avatar
matthewq4b
Do not worry about the type F fluid in the transmission won't hurt anything and you just leave it in there. If anything it will give some additional life to a worn trans.
Cam131313
Mar 31, 2016 05:05 PM
basket1021
Nov 20, 2012 05:59 AM
ke6jcf
May 22, 2003 08:35 PM
Red Raider 4x4
16
Dec 22, 2002 12:29 PM
blk_4by4
1997 - 2003 F150
Sep 29, 2002 07:32 PM
