Front end Rattle / Loose
Had it to the dealer - all good (big surprise). Just like the sunroof rattle they can't hear either (thats another story).
Note: I did put a leveling BDS 2" leveling kit and fox shocks 2 years ago, it started that winter. The truck is '18 SRW F-350. I checked everything and can't source where the noise is coming from. It sounds like a coil / shock rattle typical when you hit washboard etc. .
Realize it could be anything and probably not a fair question to ask, just getting desperate.
The only thing that it might be is that stabilizer mount that you have to replace with the leveling kit that requires like 240ft/lbs of torque. Its tight and I have torqued the snot out of it however I don't have a torque wrench that goes up that high to ensure I met that torque requirement. Seems odd if that was it, it doesn't have the issue when the temp goes above zero.
Appreciate any response.
Replaced parts and re-alignment all good.
I took the truck to a local garage that has good mechanics, they had it figured out in 5 min. The truck has so low of mileage I never would have thought the tie rods were worn, I just had a safety 4 months ago that came back all good - this has been going on since last winter. I have lost total faith in taking this truck to the dealership for any work whatsoever. Sunroof rattle same thing - I guess they wear earplugs when they take these trucks for a test drive. I think this will be the last sunroof model I buy its just not worth it.
On a good note the truck is tight and no front end rattle -
