JW Rod Shop Mustang II Suspension for 53-56 F100. Thoughts?
I have a 55 F100 and want to upgrade the stock front suspension to a Mustang II setup. I have looked at a bunch of them and think that I want to with the JW Rod Shop one. Does anyone have any experience with them. I am going to have a local shop install it. I think I want to go with the 2' drop spindles but I would like to see what it would look like. I want to stick with the 15" wheels as I like the old school look. I want to drop it, just not in the weeds. It currents has a 390FE and a 3 speed toploader. If anyone has any pics of a similar setup I would live to see them. Here is what it looks like now.
I would recommend that you take a few measurements of your truck as it sits right now and then decide how much lower you would like to go with it. Take the measurements at the frame at the point where the new crossmember will mount. JW Rod Shop should be able to provide a dimensioned drawing showing their crossmember with spindle ride height. Using your current frame height measurement as a point of reference you should be able to calculate your new ride height with the JW IFS system installed. A good point to remember...a properly installed IFS will have the lower control arms parallel to the road surface when parked. Good luck...
The mustang II is going to drop it low. As said before going with the dropped spindles will be way to much. I am running stock spindles and it sits low. Maybe not low enough some others but low enough for me. Remember your original center line does not center the wheels in the fender. It has to move forward. .
I have 7 inches of ground clearance from fender. Running board is about the same. Not sure if this is the measurement you want tire is 25 inches tall. I also have the posie springs. I may have to raise mine a bit. I went with 2 other adjustments to get it lower. I will have to wait till I can test drive it. Btw all your trucks have nice stances. Hey John do you have a rear pic of your sway bar set up?
I have a small block in mine. I bought a Heights crossmember. Then I was in person at a big parts house and showed them my upper a/arm and needed the lower to match. and also needed springs. They screwed up and mis matched everything. So I sent it back. I went with a guy named Gayle Bridges. Company is Gayleco. Customer service is great. He also will take the time to explain everything. He set me up with all I needed
I think you have achieved the perfect stance. I would not go any lower either. Love that look.
B
