Hi all, first post but happy to be here. We have a 1995 F150 XLT, 302/5 liter, 4x4. We put in a new aod transmission, and it works. It has dual fuel tanks. The front one does not work. We were using the rear tank. One day the truck just died. We didn't hear the fuel pump and couldn't get it to work so we replaced it. Truck did the same thing. It starts just fine, but once it warms up, it will die if you step on the gas past about 1/4 down. We have been trying to eliminate the problem, but after replacing the fuel cutoff switch, the egr valve, O2 sensor, Mass Airflow sensor, fuel filters, and cleaning everything out thoroughly. But the problem still exists. We let it run and warm up idling yesterday and now it died on its own without even moving it. We're trying to check connections everywhere. We even jumped the fuel pump to make it run, and we could hear and feel the pump running, but the motor would not start. We're going crazy! Would love any advice anyone has. If you have questions about it please let me know.
Thanks! Mauro @ Madness Motors Albuquerque
