Computer Chips & Tuners
ECM Troubleshoot
Old Jan 20, 2021 | 04:42 PM
ArayT's Avatar
ArayT
ECM Troubleshoot
Trying to help an old friend that has a 1995 F150 with a 302. Any help would be appreciated. His truck runs OK then it starts skipping and sputtering like crazy. We replaced the plugs, plug wires, rotor, EGR valve, removed the ECM and cleaned the connections (smelt OK) and reinstalled, none of this helped. You can clear the ECM memory it runs ok until you turn it off and restart then it starts spitting and sputtering like crazy. After running a while the check engine light comes on and start running ok again. Shut it off and it starts all over again. Would replace the ECM but don't want him to waste money if that does not fix it. Is there a way to troubleshoot this or is it surely the ECM going bad. Any advise would be appreciated.
Old Jan 20, 2021 | 06:15 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The way to troubleshoot it is to read the codes. www.troublecodes.net/ford
Old Jan 20, 2021 | 06:39 PM
torq'ta 5 8's Avatar
torq'ta 5 8
your 95 should be 3 digit codes, and if none, show up, you can try this below
Fuel Injection Technical Library » No Codes?
Old Jan 22, 2021 | 01:12 PM
ArayT's Avatar
ArayT
I will look for the codes this weekend. appreciate the help!
Old Jan 25, 2021 | 05:20 PM
ArayT's Avatar
ArayT
Guys I pulled the codes and they are 334, 225, 172 and 173. Again appreciate any help.
Old Jan 28, 2021 | 05:54 PM
torq'ta 5 8
miles, EGR could be gummed up and not closing fully, and needs cleaning.
For the DTC 334, pull and plug the vacuum line at the EGR valve. Back probe the EVP sensor to verify the reading is beween .2V and .67 VDC. If it is, re-attach the vacuum line, if it rises above .67 VDC, there is your culprit. There should be no vacuum applied to the EGR valve at idle. Take a look at the EVR solenoid, it is allowing vacuum through when it should not be applied.
see link-->
Ford Fuel Injection » EGR Valve Position sensor (EVP)
use pic to test
Chesney May
Aug 24, 2015 09:35 AM
cjennings5
Aug 9, 2014 05:30 PM
baylesr
30
Aug 10, 2008 02:35 PM
Schlump
1978 - 1996 Big Bronco
Oct 3, 2003 05:48 PM
93F150Truck
Jun 30, 2002 08:17 PM
