Regulated Return discussion
Old Sep 3, 2022 | 10:30 PM
  #76
udsuth78's Avatar
udsuth78
Originally Posted by Kwikkordead
It's ALWAYS easier to push a fluid than to pull it. I would go so far as to think that partially gelled fuel will be much more easily pushed than pulled. Even to the point of if it's jelled, it still has to resist 65psi to not get pumped. There's no getting around that law of nature. That's why I will always advocate a tank mounted fuel pump.
It hadn't occurred to me until reading this but this may be what kept me running and cattle alive 2 winters ago when we had the big freeze. Here in Oklahoma we had 3 or so days of -20ish, 7-8 days of negative temps and like 10 or 12 below freezing. Below freezing isn't anything new here but those below 0 days are not all that common any more and I've never seen -20 before then. Anyway my point is I installed my pump in tank not quite a year prior to this, and my girl never missed a lick during all of it. I passed a lot of abandoned diesels during that 1.5-2 weeks, but never a hiccup. I spent over a week of it doing nothing but tripping wherever I could find hay, plus 2 -3 trips a day from the house to our land w/ a tote full of water because the ponds got to thick break ice even w/ the loader.
Old Sep 3, 2022 | 10:42 PM
  #77
Kwikkordead's Avatar
Kwikkordead
I have every confidence that what you are saying is true.
Old Sep 4, 2022 | 04:38 AM
  #78
FinnishStroker's Avatar
FinnishStroker
But then how have i survived in -35celsius with all stock system,no tank mods and broken pickup foot...?
PROPER winter fuel and CHANGE fuel filter BEFORE freezing temps..
I still haven't decided my upcoming fuel system,keep the stock bowl or not to keep...Having a van will benewit for sure,from stock bowl delete..
Old Sep 4, 2022 | 07:08 AM
  #79
FordTruckNoob's Avatar
FordTruckNoob
Diesel fuel formulated for Finnish weather perhaps?
Old Sep 4, 2022 | 07:32 AM
  #80
Dan V's Avatar
Dan V
I haven't had a diesel gel since maybe 1989...1983 F250 with the 6.9.
I like to believe the fuel terminals account for the weather in their area. I think Leonard would agree, here in the Mpls area, we get -20 pretty regular and some -30. You just don't see many semi's stalled out.
Old Sep 4, 2022 | 07:47 AM
  #81
FinnishStroker
Exactly,my point was that with proper mainteinance and correct fuel for the weather,you'd will be fine.
Old Sep 4, 2022 | 01:44 PM
  #82
CMRML's Avatar
CMRML
ESwft,
What part is that from Driven Diesel? Does it just split supply and feed the front of both heads? That’s how it appears in the photo, but hard to tell.
Old Sep 4, 2022 | 02:02 PM
  #83
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Kind of wrong forum but id love to hear this group’s thoughts on implementing stock 99-03 fuel system to 94-97 vs typical aftermarket e-fuel.
im leaning that direction for simplicity sake and use of same filters and seals etc on both my trucks.
Old Sep 4, 2022 | 03:30 PM
  #84
ESwift's Avatar
ESwift
CNCFAB
Originally Posted by CMRML
ESwft,
https://www.strictlydiesel.com/produ...te-upgrade-kit
it is just a 3 way-1 in feeding to 2 out to the front head ports. I have it fed by a line off the airdog system. Works well. I also really like my cncfab 4 line feed. Having a hard time deciding which one to put on my engine that is going into the truck soon.
Old Sep 4, 2022 | 08:56 PM
  #85
CMRML's Avatar
CMRML
Thanks Eswft. I like that piece. I wonder what the internal milling looks like?
Guys,
What do you think of the 4-way feed blocks with no return? Essentially, 1 incoming supply line into a manifold block with 4 hoses output to front and back of each cylinder head?
I wonder what kind of hyrdaulics ares happening inside the head when fuel is pushing from the front and back of each head and meeting somewhere in the fuel rail? Instinctually I feel like there would be some weird fluid dynamics going on with fuel rushing headlong into itself in a tube (cylinder head) while being drawn out at different points along the fuel rail according to firing order.
I think I like the idea of just having fuel entering the head from one direction better.....like the stock scenario.....or at least in from one side and out from the other.
Old Sep 4, 2022 | 10:23 PM
  #86
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
I wonder what kind of hyrdaulics ares happening inside the head when fuel is pushing from the front and back of each head and meeting somewhere in the fuel rail? Instinctually I feel like there would be some weird fluid dynamics going on with fuel rushing headlong into itself in a tube (cylinder head) while being drawn out at different points along the fuel rail according to firing order..
65 psi supply from either direction, any direction, or multiple directions at once still pales in comparison to 18,000 psi spitting back into the fuel rail at four different points in time and space from each split shot injector.
That's when the fluid dynamics in the fuel rail get interesting.
Old Sep 4, 2022 | 10:40 PM
  #87
CMRML's Avatar
CMRML
Y2kw57,
Sorry but I'm not tracking. Can you elaborate on your post?
My understanding of the fuel system is once fuel enters the fuel rail in the heads, it is then routed to a chamber at each of the injectors, (which is isolated by the upper and lower o-rings of the injector) at which point the fuel is pushed into the injector at the fuel inlet, then the intensifier piston compresses the fuel to 7x the inlet pressure (ultimately resulting in 7x ICP pressure) pushing it into the barrel and then the injector nozzle.
There are check valves/***** in the injector preventing fuel from being pushed back out the inlet side of the injector.
Guys,
I hate that I even had to consider posting this P.S.: My posts are only being put up as a tool for me and maybe others learning more about this system. Any challenge or questioning of any of your posts is only put up in the interest of education, and I'm fully aware that my understanding of the topic at hand could be anywhere from partially correct, mostly correct, fully correct, to flat out wrong.
Old Sep 4, 2022 | 11:44 PM
  #88
CMRML's Avatar
CMRML
Everyone,
This is a pretty thorough explanation of the factory fuel system. Don't get distracted by this guys headband, he knows his Factory Ford Engineering. Explains some things about the Ford Factory pick up assembly that I think are pretty interesting. Do you wanna know why there is the duck bill on the outlet side of the fuel return? Did you know that the small in tank filter assembly at the pickup/return is actually called the "Thermal Recirculation Module" and that it serves some very specific functions? I wish that the Ford Factory Service Manuals explained what the Ford Engineers were thinking when they designed our trucks!
Old Sep 5, 2022 | 06:33 AM
  #89
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Y2kw57,
You yourself already linked a video in your subsequent post that explains it perfectly, albeit briefly.
The transient point where the inlet check ball is bypassed with the spillage of high pressure fuel back into the fuel rail via alignment of the annular groove in a split shot is visualized at 24:25 in the video you posted.
Old Sep 5, 2022 | 08:26 AM
  #90
RacinJasonWV's Avatar
RacinJasonWV
Interesting video. Thanks for sharing.
