CARPET WET
Old Jan 19, 2021 | 08:49 PM
ehusmann's Avatar
ehusmann
CARPET WET
Working on a 1993 F150 XLT extended cab 5.0 that has wet carpet along the left side of the tunnel. Also found he coolant overflow bottle empty and radiator down 1 - 2 inches. Radiator and hoses are new within the last six months. Have also noticed at times a very small spot of coolant on the ground. All that to ask this question. Could a leaking heater core cause the left side front carpet to be wet?.
Old Jan 19, 2021 | 08:52 PM
OhioFordFarm's Avatar
OhioFordFarm
Its possible. IF parked at a angle it could run through the duckwork and come out the floor vent. Take a white paper towel and blot the wet area. See if the towel turns green from antifreeze or not.
Old Jan 20, 2021 | 08:28 AM
jackietreehorn's Avatar
jackietreehorn
Yes it is possible, the heater core on mine leaked mostly on the passenger floor pan.
Old Jan 20, 2021 | 09:28 AM
sandymane's Avatar
sandymane
If you are hearing any gurgling inside the cabin, that is a sign that the heater core is suspect for your leak. Sandy
captdave
2004 - 2008 F150
Jan 8, 2013 07:44 AM
van o
Oct 24, 2009 04:12 PM
anojones
Feb 10, 2009 04:56 PM
96expblk
Jan 30, 2007 11:50 PM
ford429cu
1983 - 2012 Ranger & B-Series
Sep 16, 2006 01:24 PM
