LOW OIL PRESSURE WARNING 2016 6.7
Hello, New to the forum hope to get help and give help when I can, I have a 16 f350 with 84 k miles. Low oil pressure warning light comes on when sitting at a light in gear. The warning goes off when I put in Park. Never comes on while driving only when stopped with my foot on the brake. Now, what I ve done is replace the switch and the housing the oil and the filter. nothing changed. Today I installed an oil pressure gage and oil pressure was normal. Also put an oem filter on. double checked the level and used rotella 10w30 oil.
I tried to find an on line diagram of the oil system to look for choke points. didnt find a good diagram.
my recommendation is to use forscan to check the oil temp and check the coolant temp. if there is a large difference....the oil cooler could be obstructed.
sounds like you eliminated the sensors, filter, oil grade.
using thick oil tends to build up soot......
