Sponsored by: Real Truck
Airbag Code 12 on 2007 E350
Old Jan 18, 2021 | 04:45 PM
Jeff Maling's Avatar
Jeff Maling
Hi Everyone...This is my first post here...it looks like a great community!
We have a 2007 E350 Super Duty Cut-Away Van. It has an Airbag Light, which blinks Code 12.
I've found enough information to begin troubleshooting the Code 12, which indicates low voltage to the RCM.
I've checked power all the way from the battery to the fuse and the RCM connector (Red/White wire), and am getting 12V at every point including the connector at the RCM. So it appears to be receiving nominal battery voltage.
I found a troubleshooting guide that says the next check is to make sure the RCM ground is good. But the guide is for a different year, and the wire colors don't match.
Does anyone have a wiring diagram that would tell me the Pin # or wire color for Ground at the RCM connector?
Does anyone have experience with the Instrument Cluster causing the Code 12 problem? We've had a few cases where all the gauges go to zero and then right back to normal. I understand this is a common problem with Super Duty instrument clusters. The troubleshooting guide said to check the Instrument Cluster connection, but again the wire colors and pinouts don't match my vehicle.
Thanks for the help!
Old Jan 19, 2021 | 02:02 PM
Jeff Maling
Hi Folks...does anyone have any ideas about my airbag question?
All I really need to know is the wire colors for: 1) The RCM ground wire, and 2) The RCM Indicator Lamp wire that goes to the instrument cluster.
Thanks!
Old Jan 19, 2021 | 05:55 PM
projectSHO89's Avatar
projectSHO89
Looking in the factory service manual for you specific vehicle, it explicitly says to replace the RCM (airbag control module) for an LFC 12. No troubleshooting steps are given, it says just replace it. Chances are, you might find someone on eBay who can "fix" it so it is usable again.
Probably a rabbit trail, but feel free to go on down it.
1. Black/Light Green. Goes to ground G201 located under the driver's seat.
2. Black/Yellow. There's nothing wrong with that wire since it is able to communicate the LFC to the IC.
Old Jan 19, 2021 | 06:45 PM
Jeff Maling
Thanks for the helpful insight.
There's a good chance the RCM is bad. Code 12 is for low voltage, but the input pin reads nominal voltage. So it could be an internal failure.
I'll look at options. Is an RCM tied to VIN, or can I just get any used one?
We've also seen the gauge cluster drop out a few times. I think I'll change that first to be sure that's not the problem. Reason I'm wondering is that the Airbag Indicator Lamp is a little dimmer than the other lights. I'm wondering if the voltage on that circuit is low due to an instrument cluster failure of some kind.
I appreciate the help!
Old Jan 19, 2021 | 07:21 PM
projectSHO89
Your definition of the LFC is incorrect, probably is for a different vehicle. For your vehicle, it is given as "ECU (RCM) is Faulted".
Old Jan 20, 2021 | 06:56 AM
Jeff Maling
Thanks projectSHO89....that's super helpful. I'll go ahead and change the RCM.
Can I just get one from eBay?
Or is it better to send out the original for repair?
I appreciate the help...Jeff
Old Jan 20, 2021 | 07:20 AM
projectSHO89
I have no opinion on which avenue to go down, I'll leave that up to you.
Old Jan 22, 2021 | 11:59 AM
Jeff Maling
I think I'm going to try sending both the instrument cluster and the RCM to a rebuild house and get both fixed and tested at the same time...that should solve both my problems.
I'll probably be back with other questions...but for now I think I'm all set on this topic.
Thank you again...I appreciate the help.
Dreeesh
Electrical Systems/Wiring
Sep 30, 2019 10:03 AM
GotThreeOfThem
2004 - 2008 F150
Feb 21, 2016 11:51 AM
shore
Mar 17, 2013 11:15 AM
ghenryl
Aerostar
Nov 17, 2007 11:35 PM
KJUNDAD18
Oct 29, 2004 11:15 AM
