Portable air compressor
Old Jan 18, 2021 | 03:27 PM
drdit92's Avatar
drdit92
I've had a Viair 12 volt that was expensive but small. I somehow bricked it on a camping trip in November. It turns on but makes a wheezing sound and no air comes out. Of course I'm well past the 1 year warranty. Planning to pull the fiver for work later this week and need a compressor. Hate to invest in a Viair for the $$ and lack of durability. Thoughts? 6 gallon pancake compressors are bigger but cheaper. There's a 1 gallon Ryobi at HD but not sure that's enough?? Any advice welcome.
Old Jan 18, 2021 | 04:06 PM
muhford's Avatar
muhford
Are you looking for a portable compressor or a 120v compressor? Are you just filling tires?
Old Jan 18, 2021 | 04:14 PM
drdit92's Avatar
drdit92
Portable. Filing tires.
Old Jan 18, 2021 | 04:21 PM
Akley88's Avatar
Akley88
i use my kobalt 24v compressor for tires and my air bags. works great but i have a bunch of kobalt 24v tools
Old Jan 18, 2021 | 04:24 PM
muhford's Avatar
muhford
All the 12v pumps are cheaply made and run super hot. A 120v pancake compressor might fill up one tire before it needs plugged in. Gasoline compressors are expensive unless you make one or find a used one.
If you have a spare tire that should get you to a gas station with air.
Old Jan 18, 2021 | 04:36 PM
hobohilton's Avatar
hobohilton
Harbor Freight......... $70............ They all come out of the same factory in China.
Hobo
Old Jan 18, 2021 | 04:42 PM
drdit92's Avatar
drdit92
All the 12v pumps are cheaply made and run super hot. A 120v upancake compressor might fill up one tire before it needs plugged in. Gasoline compressors are expensive unless you make one or find a used one.
I need something to air up cold tires 10 psi when temps drop,etc. That's what I used the Viair for. Used it several times on a 3 month trip to Alaska, for example. I rarely find gas stations with air that goes above 45 psi. I need 80.
Old Jan 19, 2021 | 07:54 AM
winglesss's Avatar
winglesss
The symptoms sound like the internal reed valve has stuck in the open position.
Has the problematic compressor been disassembled / inspected for possible repair?
Old Jan 19, 2021 | 08:21 AM
kgburns's Avatar
kgburns
I use a Ryobi 120 PSI portable compressor, but I have a lot of Ryobi tools and batteries already. It's quite a bit more if you have to buy the compressor, battery and charger all at once.
Old Jan 19, 2021 | 11:10 AM
mwebster22's Avatar
mwebster22
Here’s what I did:
https://www.ford-trucks.com/forums/1...l#post19547393
Old Jan 22, 2021 | 11:10 PM
Doolydude's Avatar
Doolydude
I bought a 3 gal 120V compressor from harbor freight to fill the tires on my Dually, it works great. I power it with an 1000 Watt inverter inside my Camper.
the inverter comes in handy powering other items in the camper also laptops cell booster etc. just wired to my camper batteries, could also be wired to your on board truck battery also. The inverters don’t take up much space.
Tugboatguy
All Things Towing
Nov 4, 2020 07:43 PM
cbzdel
May 23, 2012 08:21 AM
82airborne82
Paint & Bodywork
Nov 9, 2010 07:15 PM
knightshield
Garage & Workshop
18
Mar 7, 2004 03:24 AM
mr4speedford
Garage & Workshop
Sep 27, 2003 09:54 AM
