Key forward no start
Old Jan 16, 2021 | 05:59 PM
swhitney133's Avatar
swhitney133
My 1988 early idi f 350 starts by bypassing starter relay with my remote starter unit. New ignition switch and starter relay today. Problem not solved . I was having problems with door locks until I replaced the ignition switch. The single wire going to starter relay is the information I need for diagnosing my problem. Thanks you all.
Old Jan 16, 2021 | 06:18 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
is that Manual or Automatic and is it with or without the RAP Module ?
I have the schematics for the 1998 F250 should be same as the 350 but need to know what Transmission so I can post the correct set for you.
this is really the wrong forums for the 98 too as our last year was 1994
Old Jan 16, 2021 | 07:11 PM
swhitney133
Automatic trans
Old Jan 16, 2021 | 07:43 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Ok.. Thanx this is what I show for it...
Old Jan 16, 2021 | 08:48 PM
swhitney133
It’s a 1988 xlt lariat 7.3 l diesel early idi c 6 trans
Old Jan 16, 2021 | 08:58 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
ok I see you changed the 1998 hang on I have that info too.
Old Jan 16, 2021 | 09:03 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
here ya go 1988 F350
it's a lot simpler
Old Jan 17, 2021 | 08:41 AM
tjc transport's Avatar
tjc transport
i ain't rite
when you turn the key to start, do you feel resistance and does it return to the run position when you release the key?
if not, the ignition actuator in the column is most likely broken. common issue with these older trucks.
good news is it is only a $17 part, and takes around 1.5 hours to replace.
Old Jan 17, 2021 | 01:02 PM
DarkOverCast's Avatar
DarkOverCast
You also have to adjust the ignition switch when you install it. Does it start if you move the gear selector to neutral?
bettyford93
18
Nov 5, 2014 10:29 AM
judyms772
Jan 22, 2006 11:39 PM
terrmat
May 21, 2005 01:38 PM
Mach73
Jul 11, 2004 05:08 PM
carpe_diem
Electrical Systems/Wiring
Jul 13, 2003 01:19 AM
