I have been having a rough idle condition. The motor idles fine for a second then spits or sputters like a miss but just feels rough. It works better in the cold weather and when under a load such as the A/C compressor being on. I have replaced the O2 sensor, wires, plugs, MAF sensor, distributor cap/ rotor. I just got an emissions test that showed the motor running very lean. How do I get the engine to run richer or what causes it to run lean?
This may be totally wrong but I had similar symptoms with my old 90 F150 at one time and I replaced the fuel filter. Fixed it that time. Could also be the regulator.
Don't buy a new regulator yet. Check the fuel pressure on the outbound side of it first. You should be getting around 39 PSI. It could also be dirty injectors or a dirty throttle body. The fuel pressure regulator is located at the back of the intake manifold it is a small round can about 2" in diameter with fuel lines running to it.
