2000 expedition runs rough
Old Apr 8, 2013 | 08:55 AM
Trado11's Avatar
Trado11
I have a 2000 expedition with the 5.4. I have a problem with running rough giving lean codes. It idles fine but hesitates a second when throttled. Driving is rough sometimes mostly when it goes under a load. When it pulls if I hold the throttle pedal where it is it sputters and bucks but if I kick it down it smooths out. Changed fuel filter, cleaned throttle body and maf sensor, rebuilt injectors and replaced 3 vac hoses that looked iffy .
Without just replacing sensors any ideas what to test
Old Apr 8, 2013 | 09:37 AM
alloro's Avatar
alloro
Follow the PCV hose around to the back center of the intake manifold. There you will find a rubber elbow that is often damaged and causes a lean condition.
Old Apr 8, 2013 | 09:49 AM
Trado11's Avatar
Trado11
Yeah that's the one coming off the plenum??? Looks ok. My fuel pressure is a little low at 32psi
Old Apr 8, 2013 | 02:16 PM
alloro's Avatar
alloro
When was the last time the fuel filter was changed?
Old Apr 8, 2013 | 02:31 PM
Trado11's Avatar
Trado11
Recently after problem started no change
Old Apr 8, 2013 | 03:40 PM
alloro's Avatar
alloro
In that case go back to the elbow and remove it. The damage is not always obvious.
Old Apr 8, 2013 | 03:58 PM
Trado11's Avatar
Trado11
The hose is fine if I plug the pcv I can not move air at all. I did notice the pcv always has flow if I blow through both ends. Is that normal???
Old Apr 8, 2013 | 05:12 PM
alloro's Avatar
alloro
Some flow is okay, but there should be some resistance. It shouldn't flow easy like an open tube would.
Old Apr 8, 2013 | 05:56 PM
Trado11's Avatar
Trado11
I now tested it running and there is good vacuum at the pcv so I believe that is ok. Uuugggghhhh
Old Apr 9, 2013 | 08:14 AM
Trado11's Avatar
Trado11
Just thinking here but does this sound like a COP failing. I do not see the tach move but it idles fine and only acts up loaded??
Old Apr 9, 2013 | 12:08 PM
r2millers's Avatar
r2millers
It's easy enough to clean the pcv valve, soaking in gas for a few to ensure its operating properly.
To alloro's point, changing out the pcv elbow can't hurt as its the most common source for pulling lean bank codes.
For your cop question, yes the boots start to crack and allow spark energy to escape, finding the plug hole sides to ground and create inconsistent firing.
See my recent post on what happens to these boots. Most of the time you can just change these boots to solve the issue. Like most electronics, it either works or it doesn't and these cop's are pretty durable.
https://www.ford-trucks.com/forums/1...pak-boots.html
Old Apr 9, 2013 | 07:00 PM
Trado11's Avatar
Trado11
Expedition fixed. It was one of the cop's
Old Apr 9, 2013 | 07:02 PM
Trado11's Avatar
Trado11
Anyone have any luck with the eBay ones??
Blake12
Jan 25, 2016 08:08 PM
macaroni727
Modular V8 (4.6L, 5.4L)
Oct 13, 2015 05:49 AM
Chopfather
13
Jul 28, 2014 07:34 PM
creed7276
1997 - 2003 F150
Aug 6, 2013 05:58 PM
cvpi71
Apr 22, 2008 11:17 PM
