Very odd thing happened!
Old Jan 12, 2021 | 09:29 AM
SkySkiJason's Avatar
SkySkiJason
Then, check OD switch wire if you haven’t yet.
Old Jan 12, 2021 | 11:09 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by bigb56
On your 2002 there is a small plastic junction box on the driver's side fender liner with a cable from the battery coming into the front and two fusible links coming out of the back and heading to the fuse box. All 3 are held together on a post with a nut. This connection is known to corrode and eventually fail which will shut you down. Yours might be in the early stages of failure, just something to look at.
That is what I was describing above, but you did a much better job at describing it. Thank you for that.
Old Jan 12, 2021 | 12:31 PM
FinnishStroker's Avatar
FinnishStroker
I vote CPS cutting out.
Sometimes it wont even lit SES light.
Read codes.
Old Jan 12, 2021 | 03:33 PM
SteveH-CO's Avatar
SteveH-CO
I had exactly this symptom when my CPS went out - instant igntion cut, no codes, restarted right away. Replaced the CPS and totally fixed.
Old Jan 12, 2021 | 04:10 PM
Brother Les's Avatar
Brother Les
Run down on CPS
https://deadheaddiesel.com/cam-position-sensor-7-3-cps/
Old Jan 12, 2021 | 06:03 PM
RA101725's Avatar
RA101725
Banned
Read codes.
that would my first guess.
Old Jan 13, 2021 | 07:28 AM
Listor's Avatar
Listor
Sorry guys, had no time to mess with it yesterday, had to play Grandpa and help kids with school yesterday, OMG what are they teaching my kids!
ANd well after that I was wore the heck out, How did i get so old! LOL
Old Jan 13, 2021 | 07:43 AM
Brother Les
You lived....
Carpe' Diem
Old Jan 13, 2021 | 09:45 AM
Sous's Avatar
Sous
FTE Emeritus
No worries, we will be here to offer advice and guidance when you get to it.
Also, the getting old thing is better than the alternative. GFML!
Derekdotcom
21
May 29, 2020 02:30 AM
thomabb
34
Apr 21, 2017 11:52 AM
D Lab
Escape & Escape Hybrid
Mar 27, 2014 01:04 PM
DHamSTER
Sep 10, 2013 09:51 AM
