Total Intermittent Unreproduceable Electrical Failure
New ghost in the machine.
Pulled out of the driveway two days ago to go trailer a wrecked car home. Got about half a mile up the road, and my electrical system started flickering. Engine died, dash went nuts, everything is clicking on and off real fast. This went on for a minute or two, then stopped. After a little internal debate, I decided to continue on.
Ran fine for another mile or so. Hitched up the trailer and checked the lights, everything A-OK. Started rolling down the lane and the truck went dark. Engine shut down, no sign of electrical power anywhere. It was as if my batteries had been suddenly abducted by aliens. Truck stayed dark for about 5 - 10 seconds, then like a switch was thrown all the electric came back on. Dropped the trailer and drove back to the house without incident. Not towing a car like this.
Checked the battery connections. Looked really good and tight. Pulled and cleaned them anyways.
Pulled the fuse box out from under the dash and looked for water damage. Absolutely no sign of moisture or corrosion anywhere on the box or anything else under the dash.
Started the truck and turned every electrical item I could think of on. Truck sat and idled for 15 minutes without a hiccup. Voltage at the batteries was normal. I wiggled wires everywhere with no effect.
Decided to quit for the night. Got into the truck to move it to it's parking spot and POOF, all went dark again. Engine died, heater blower, radio, headlights, interior lights, all dark. About 5 seconds later, everything came back online.
No CEL. No other symptoms. She was either running perfectly or had no juice at all.
I drove it last night to the mechanic I use. 7 miles, bumps, potholes, stop and go traffic, no issues.
Just spoke with the mechanic. They can't reproduce the problem. I told him I can't reproduce it on demand either. I asked that they put it up on the rack and check all the ground points.
And that is where I am now. Slightly broken hearted that the old girl is hurting and sitting in a strange garage.
Our family asks in this time of need that in lieu of flowers, please send any recommendations that may speed her recovery.
Not sure what year your is but on my 02 there is a small plastic covered junction on the drivers side fender liner with a nut inside that has 3 wires under it. One wire comes from the batteries and the other two are gray fusible links that connect to the fuse box and provide all the electrical power. This connection is subject to road grime and can get corroded and deteriorated especially if the plastic cover is loose or open.
Less likely but I'll throw it out there: mine had equally random electric failure, but limited to the PCM/engine. That was the ignition switch mounted on the steering shaft, other pic below.
And thanks for the entertaining, if sad, tale.
I had a loose wire in the column a couple years ago that was causing some odd symptoms. Found it by accident. This time it was really different. My trailer brake controller even went dark! It was like in the movies when an EMP wipes out all electrical activity. Something out of the Twilight Zone, for those of us old enough to remember that show.
I will definitely let you guys know what is found, either by me or the mechanic. Had to work today so I can't hover over the mechanic's shoulder.
