What is this called?
Old Jan 11, 2021 | 09:23 PM
Chrisp1999's Avatar
Chrisp1999
It'd got alot of air in them but the brakes still work and stop
Old Jan 11, 2021 | 09:56 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Only until you lose enough fluid so that even the front won’t work.
As stated in post 15, the rubber hose only goes from the crossmember in front of the gas tank to the axle tube. That is a separate steel line (or two) from the crossmember to the front of the truck.
Old Jan 12, 2021 | 09:44 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by OhioFordFarm
However It looks as the hole is stripped.
You have some good eyes and indeed, it does look stripped.
Old Jan 12, 2021 | 10:13 AM
SFaulken's Avatar
SFaulken
Do they sell plugs to plug the whole where the bolt used to be
Yep, they do. I'm not going to tell you where to get them, or part numbers. You're going to have to figure that out on your own, because it's making your truck a danger to other motorists if you do it for any reason other than to move it a short distance to where you fix it properly.
rsh1966
Oct 5, 2018 09:43 AM
Lee Patrick
Jun 23, 2018 09:03 AM
5X5
Dec 22, 2015 04:13 PM
quisp-n-quake
Mar 3, 2008 10:31 AM
