1963 223 inline six question
Old Jan 11, 2021 | 11:19 AM
63Vanette's Avatar
63Vanette
Greetings all....I recently purchased a 63 Ford P3500 parcel delivery "Vanette" and it's been sitting in the weeds for decades. The engine turns over fine with a breaker bar and feels like it has good compression. I pulled the oil plug and very little oil came out. When I looked inside the drain plug hole, there is something sitting about 1/8 of an inch behind the hole. I've never been inside a 223 but have been inside many other engines and have never seen anything so close to the inside of the pan. Is this normal for the 223?
Old Jan 11, 2021 | 02:12 PM
Mixer man's Avatar
Mixer man
Welcome, 63Vanette!
Oil pickup screen, but it shouldn't be sitting on the bottom.
Old Jan 11, 2021 | 02:49 PM
63Vanette's Avatar
63Vanette
Originally Posted by Mixer man
Welcome, 63Vanette!
Thanks Mixer. I thought it was probably the screen too but it seemed like it was in an odd position. I stuck a probe in the drain hole and it's literally right there, but it won't move. I guess I'll have to drop the pan and see. BTW, as I logged back in I realized I was in an earlier year forum so I appreciate the answer.
Old Jan 11, 2021 | 03:29 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Welcome to the forum!
Does your oil pan have a large-diameter plate on the bottom with nuts? Most trucks have that, it is a "cleanout plate" that can be dropped to access the oil pickup screen for cleaning. The screen is usually less than 1/2" above the bottom of the pan inside an inverted bell that has the actual pickup tube near the top.
Old Jan 11, 2021 | 03:42 PM
63Vanette's Avatar
63Vanette
No, it's a solid pan however, it looks easy enough to drop. There's no suspension in the way. The only thing I have to contend with is a crossover exhaust pipe near the back shallow side of the pan. I should be able to clear it..
kheisler
Jan 20, 2019 03:36 PM
Mcrafty1
Apr 15, 2016 01:25 PM
z1121jack
Aerostar
Oct 25, 2008 03:20 AM
Flaflathead
Mar 24, 2006 06:23 PM
rebelbob
Oil & Lubrication
Jun 27, 2003 07:45 PM
