I’ve seen lots of post to answer question on 4wd models. But nothing for 2wd.
I have a light grinding sound when turning full right. Sounds coming from right side. I’ve checked the wheel hub and it seems fine. But still not ruling it out as the problem. Is there any common problem areas to look for?
2015 expedition. 96,000mi
My tires were rubbing the inner fender well liners when turning sharp, a couple of holes with zipties holding the liners back out of the way and no more rubbing. It was louder than I thought it would be for rubber on plastic but it fixed the noise. Any rub marks anywhere in the fenderwells?
