Automatic Door Locks?
Old Oct 25, 2003 | 12:18 PM
ElisaW's Avatar
ElisaW
Question Automatic Door Locks?
My last vehicle was an Expedition and I read on this site how they came with the automatic locks defaulted to OFF. Someone had posted instructions which I used sucessfully to turn them ON.
Is the Excursion the same way? The locks are not automatically on, although I've read on here about how some of you have turned them off. Is there a way I can get them on? (I have 6 kids and the auto locks just make me feel better.)
Thanks.
Old Oct 25, 2003 | 01:12 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
On the newer 2003-2004 models and maybe even the 2002 models, the doors automatically lock once you put the vehicle into gear. I test drove a 2003 or a 2004 (don't remember which one) and the doors locked once I shifted it into gear. Although I'm not sure how you would go about turning them on with other model years. What year Excursion do you have?
Old Oct 25, 2003 | 02:33 PM
jschira's Avatar
jschira
Do you have the exterior door keypad?
If so, here is the procedure:
1. enter your 5 digit code;
2. press and hold the 7/8 button;
3. press and hold the 3/4 button.
You should get a horn chirp followed by a honk if the system is enabled. If the system has been diabled, you only get the chirp.
You can also use the door lock/unload button on the driver's door.
Here is that procedure:
1. turn the key to the ON position;
2. press UNLOCK 3 times;
3. turn the key OFF;
4. press UNLOCK 3 times;
5. turn the key ON, the horn will chirp;
6. press UNLOCK then press LOCK;
The horn will chirp once if AUTOLOCK was disabled and twice (one short, one long) if AUTOLOCK was enabled.
7. turn the key OFF.
The horn will chirp.
This stuff is all in the manual. About page 113.
Old Oct 25, 2003 | 04:59 PM
Toreador_Diesel
Does this work on the 2000-2002 Excursions? Or does only apply to the 2003-2004 Excursions?
Old Oct 25, 2003 | 09:17 PM
ElisaW's Avatar
ElisaW
Great. I'll have to try that. Mine is a 2000 so we'll see what happens. Thanks guys.
Old Oct 25, 2003 | 09:26 PM
ElisaW's Avatar
ElisaW
Okay. That didn't work. I DO have the door keypad. It's a 2000, and the only thing I've seen in the manual says to push L to lock the doors and U to open them. (DUH)
Any other ideas? It seems weird that my Excursion had auto locks (1997) and this one doesn't. ??
Old Oct 25, 2003 | 09:49 PM
jschira's Avatar
jschira
Sorry. I looked up the procedure in the 1998 Expedition Owners Manual and its the same, so that is how to do it.
It does seem strange that Ford does not allow the disable feature in the 2000 X.
Maybe the 2000 X does not have the autolock feature, so there is no reason to tell you how to turn it off?
Old Oct 25, 2003 | 10:18 PM
ElisaW's Avatar
ElisaW
I dont want it off...I want it ON. lol *banging my head on the desk*
Old Oct 26, 2003 | 06:18 AM
jschira's Avatar
jschira
OK. Maybe 2000 X's don't have it so that there is no way to turn it ON.
Old Oct 26, 2003 | 08:46 AM
rlh68050's Avatar
rlh68050
Heres the scoop guys. The auto door lock feature is only available on the 2002 and newer models. 2000 and 2001 don't have this option.
Old Oct 26, 2003 | 10:08 AM
ElisaW's Avatar
ElisaW
Like I said, seems weird that my 97 Expedition had it, and my 2000 Excursion doesn't. argh. And I used to like Ford....
Old Oct 27, 2003 | 04:42 PM
Landyot's Avatar
Landyot
Bear in mind the the autolock feature may possibly be a mandated thing for "passenger vehicles" that have electric locks. The Excursion does not have to comply with "passenger vehicle" requirements in a lot of aspects.
I'm only guessing here, and I DO wish my 2001 Limited had them, though.
Old Oct 27, 2003 | 06:05 PM
jschira's Avatar
jschira
Nope. I've got a 2001 Chevy and 2-2002 Volvos. None of them have autolocks.
The autolocks are a PITA when hooking up a trailer. So is the "Beltminder" seatbelt dinger (one of the most annoying features EVER put on a vehicle). Whoever put these features on the truck never towed a trailer.
Then again, maybe they did because both can be turned off.
1amante
Feb 26, 2014 06:27 AM
rustyfuryiii
Feb 12, 2011 03:21 PM
cnelso48
Apr 27, 2009 10:44 AM
FDXFX4
2004 - 2008 F150
Apr 2, 2006 01:10 PM
cparks
Oct 27, 2005 05:06 AM
