IMRC?
Old Jan 8, 2021 | 01:49 PM
bl2009's Avatar
bl2009
IMRC?
What a pain that system is. Can I just block open the butterfly valves and be done with it? I'm just not into disassembly the whole top part of the engine to replace some little bushings (even if I could find them a local parts house). Just a bad Idea from FORD. Tired and broke, but need transportation. bl
Old Jan 8, 2021 | 02:59 PM
Johnny Paycheck's Avatar
Johnny Paycheck
It’ll run like sheeit and you’ll have to hit the pedal harder to make up for it. Quite frankly, it would probably run better with them wired closed, if you can stay away from ~3500 rpm romps, which is when the butterflies open up.
(Been there. Just fix it. The real PITA is the two torquings of the cover screws , especially by the firewall.)
O’Reilly will definitely have them. I’ve got mine apart right now to replace some loose bushings. Maybe I’ll finish up this weekend then reward myself with a massage afterwards. I’ll need it.
mrpotatohead
Sep 13, 2018 08:49 PM
78Puller
May 25, 2018 03:32 PM
vdaily89
Jun 30, 2005 06:27 AM
mkeeton35
Feb 5, 2005 08:05 PM
AKFord
Jul 1, 2004 02:39 AM
