jerking when turning in 4 high
Old Jan 8, 2021 | 11:41 AM
Jeremy Workman's Avatar
Jeremy Workman
My 85 f-150 jerks when turning in 4 wheel drive at low speed going forward and reverse especially on slick surfaces. U joints in the front driveline maybe? They have slop.
Old Jan 8, 2021 | 11:42 AM
Jeremy Workman
Old Jan 8, 2021 | 11:49 AM
Franklin2's Avatar
Franklin2
That is normal. When you are in 4x4 and make sharp turns, the wheels and driveline get in a bind. What you are feeling is it binding up and then slipping and getting out of the bind, and then it binds again. As long as the wheels can slip, either in snow, dirt or gravel, you are fine. If you turn sharp on dry pavement, most of the time it will finally break loose and unbind itself, but other times it can break a u-joint. So try not to turn sharp when it's dry with lots of traction.
Old Jan 8, 2021 | 11:50 AM
Franklin2's Avatar
Franklin2
Old Jan 8, 2021 | 11:54 AM
Jeremy Workman
Ok thanks, I was wondering if that was the case because I have lots of new front end parts on the truck and it still did it. U joints in the front driveline are next.
Jeremy Workman
Jan 8, 2021 11:50 AM
Rheingar
Dec 19, 2016 07:35 AM
1bigblack250
Feb 17, 2014 06:41 AM
HunterFord
1997 - 2003 F150
Nov 7, 2004 03:28 PM
BlackCrownVic
Oct 20, 2003 05:13 AM
