351w possible Crack?
Old Jan 6, 2021 | 04:15 PM
Daniel Kroetsch's Avatar
Daniel Kroetsch
Trailering
Hello, I was tearing down a 351w ho from a 1986 f150 and I noticed a hole in the block. It's under the intake manifold, and when you look through it it goes to the timing chain. I took a photo from the front side of the engine and it looks like it might have a crack running down from it. Is this block worth keeping or should I get another one??
This one is a little wprry some too.....
Old Jan 6, 2021 | 04:24 PM
hobohilton's Avatar
hobohilton
https://www.magnaflux.com/Magnaflux
In this day and age, hang onto the block, even if you replace it... Hole and crack is repairable. Could be a worth while spare to keep around... Just sayin'
Hobo
Old Jan 6, 2021 | 05:46 PM
Conanski's Avatar
Conanski
That does look like a crack but it may be of no consequence, can you zoom out and show the general area where it is located?
Old Jan 6, 2021 | 05:59 PM
Daniel Kroetsch
Trailering
It's right in behind where the cam timing gear is. To the right of it is where the distributor goes in. I also checked the ring gap and its .003 over what the max tolerances are.
Old Jan 7, 2021 | 10:44 AM
78Fords's Avatar
78Fords
I have a similar hole in my block that looks like it was an accident. Right behind the cam gear, an irregular shaped hole. never gave me any problems
Old Jan 11, 2021 | 06:00 PM
DaveMcLain's Avatar
DaveMcLain
That hole looks normal to me and I think what looks like a crack is a paste ooze line from the cores used to cast the block.
71fordkid
Jul 14, 2021 02:18 PM
TexasGuy001
WTB - Parts & other
May 18, 2017 01:10 AM
ImSoQuazy
Ford Truck Parts for Sale
Mar 11, 2013 04:18 PM
RIKIL
Mar 4, 2010 03:55 PM
pintoches
Missouri Chapter
16
Jun 2, 2009 07:07 AM
