Replacing a key fob
Old Jan 5, 2021 | 11:53 AM
Bearwhiz's Avatar
Bearwhiz
Replacing a key fob
I seem tohave lost one of the key fobs to y 2019 F250. Has anyone else had to replace one? If so did you go through Ford or off brand? Any help would be apprecited.
Old Jan 5, 2021 | 12:20 PM
ford390gashog's Avatar
ford390gashog
With key and programming you should be able to have the dealership do it for 500.00 or so.
Old Jan 5, 2021 | 12:21 PM
Motown Fire's Avatar
Motown Fire
I bought 2 on eBay, had them cut at a local hardware store & programmed them.
Old Jan 5, 2021 | 12:23 PM
ford390gashog
That works and is the cheapest option, it however requires two working keys which the OP doesn't have.
Old Jan 5, 2021 | 01:47 PM
GABAR's Avatar
GABAR
Sorry to hear that but you’re going to have to open up your wallet for this situation.
If you go through a Ford dealer or a locksmith that has the proper equipment, you’re going to be out of several hundred dollars.
Old Jan 5, 2021 | 02:02 PM
cpobst's Avatar
cpobst
I've reprogrammed several keys for steel body 6.7's using Forscan. I'm not sure if it can do the 17' and newer keys.
Old Jan 5, 2021 | 02:55 PM
Beast 17's Avatar
Beast 17
Reputable Locksmith
I lost one of my fobs also. Flip key style. Locksmiths sell the factory fobs. I bought a new Ford OEM fob from a locksmith. Fob, cut the key and program it was $300. Took him 20 minutes for everything.
Old Jan 5, 2021 | 05:18 PM
camperfanatic01's Avatar
camperfanatic01
There are places who will duplicate existing key and chip so that the computer thinks it’s the same key, this works ok as long as you don’t have memory function or use the my key options. This is much cheaper.... check eBay.
toys4dlr
Sep 21, 2024 06:44 AM
sne43
Transit Connect
Jul 8, 2019 02:22 PM
tlcsr66
Mar 1, 2019 07:05 AM
Yaga1973
2009 - 2014 F150
Feb 16, 2014 09:58 PM
PyroManiak
Aerostar
Nov 20, 2001 03:03 PM
